M7 Screws
M7 Screws
Home › Forums › Workshop Tools and Tooling › M7 Screws
  • #872077
    Vic
      @vic
      M7 seems to be a non preferred size, except on Cycles. It’s certainly a size I’ve never been tempted to use until now. I have a project though where it may be better suited than M6 or M8. The 1mm thread pitch will be fine for the job. Anyone else use this thread size?  There seems to be no difficulty in getting M7 cap head socket screws. Many of them in Titanium which is ok, and the prices are ok given I only need a small number. I’ve used titanium screws before and some of them in a nice shade of blue, not that the colour particularly matters.
      #872083
      noel shelley
        @noelshelley55608
        They are used in the motor trade ! The peugeot 1.9 diesel uses them on the injector pump wheel to draw it off the shaft. There are many suppliers on the net, Spalding Fasteners is one. Hex head (11mm) BZP. Noel.
        #872088
        Neil A
          @neila
          I’ve only encountered M7 fasteners on the studs holding the camshaft bearing caps on a Volkswagen Polo engine. At work when we changed from imperial fasteners to metric, it was quickly discovered that M6 x 1 was not a good replacement for 1/4 UNF. The fitters found it all too easy to shear the M6. After that the smallest size used was M8 x 1,25 for holding parts together. M6 x 1 was only regarded as good for holding on nameplates and the like, not for anything important.
          It is a pity that M7 and also M9 were designated as 2nd choice sizes, I think they would have been a better replacement for 1/4 and 3/8 UNF. We did use M14 x 2, another 2nd choice thread, to hold fuel injection pumps to the cambox. M12 being too small and M16 being too large.
          In manufacturing, if you need to make lots of specials, there is no problem. It’s only if you want “off the shelf” that you find yourself limited. If you make the threads yourself, then there is no real problem.
          Vic
            @vic
            Thinking back (many years) I’m wondering what size the con rod bolts were on some of the Ford engines I worked on?
