Warco 220
Warco 220
Home › Forums › Manual machine tools › Warco 220
Viewing 25 posts - 1 through 25 (of 48 total)
  • #578299
    Sam Bernard
      @sambernard62918
      Hi everyone, I recently brought a new lathe a warco 220. Unfortunately it didn’t come with any change gears apart from a couple for the feed.
      would anyone who owns one be willing to help me figure out if I’m missing any bits eg. Going from feed setup to screw cutting setup, is there any bushings etc I need to make up. If you could give me sizes etc of the parts I would be most grateful.
      also with regards to the change gears would I be correct in believing they are module 1.5 with a 20 pitch.
      I’m thinking I may buy some 1.5 spur gears and modify them to fit. Any suggestions?
      #14433
      Sam Bernard
        @sambernard62918
        Warco 220 Need help with missing parts please
        #578359
        Dave Halford
          @davehalford22513
          Might be something in here
          #578370
          not done it yet
            @notdoneityet
            Use the formula for calculating the MOD, using the (tooth count + 2) and diameter of the gear, to confirm, or otherwise, your belief.
            #578375
            John Haine
              @johnhaine32865
              I assume you mean mod 1.5mm, 20 degree pressure angle?
              #578376
                Ive not seen MOD expressed in mm before, generally just a number eg 1, 1.5, 2, etc which once multiplied by pi will give the circular pitch in mm.
                20pa would be most likely.
                Divide the OD by number of teeth +2 to get the MOD
                #578378
                Nicholas Farr
                  @nicholasfarr14254
                  Hi Sam, this chart shows all the change gears that came with the lathe I have Selection Chart there is a little info about the machine Mashstroy there are some oddments of info in my Warco 220 album I may be able to have a look at my change gears later or in the next day or two.
                  Regards Nick.
                  #578381
                  Peter G. Shaw
                    @peterg-shaw75338
                    There is something odd, which frankly I haven't looked into so don't understand it, in that the two largest gears, I think it's the two largest, are stamped with a different number compared to the others. Unfortunately, they are on the machine and this morning is the coldest yet this winter! Brrrrr….
                    Sam,
                    Have you got the so-called manual that goes with the lathe? If not, then I have a copy of the original pink handbook stored on my computer complete with their version of English! It's no big deal to email it to you if you wish. I've also got a copy that Nick Farr sent me: this version being done by Warco (I presume) and is in better English and printing. I'm sure Nick won't mind me saying this.
                    I've also got photos, drawings, info, about some of the bits & pieces of the lathe – unlike Nick, I haven't got an album, so if you want something, ask, and if I've done it, then it's yours for the price of an email.
                    Cheers,
                    Peter G. Shaw
                    #578384
                    Nicholas Farr
                      @nicholasfarr14254
                      Hi Peter G., I have no problem with you sharing any info that I've sent you regarding the Warco 220 lathe.
                      Regards Nick.
                      #578391
                      John Haine
                        @johnhaine32865
                        Posted by JasonB on 04/01/2022 08:34:58:
                        Pitch diameter = #teeth x mod in mm. So the units of mod are mm. Normally they aren't included as "mod" is assumed to be a metric system of gear definition, but I wanted to be clear since the OP said a 20 pitch. I am assuming that a pitch of 20 DP is not intended! Also it would have to have units of mm to give the circular pitch when multiplied by pi.
                        #578401
                          John, agree the answer is metric but I've never seen it written as Mod#mm. Much the same way as we don't write 32DP" or 32DP inches but all the calcs using the DP give an answer in inches.
                          #578405
                          not done it yet
                            @notdoneityet
                            JB
                            DP would be in 1/inch in units as it is a number (no units) divided by a length (diameter, in inch units).
                            I suppose if one looks up the definition of DP (from a proper text), it will define the result of the calculation as the numerical DP, not including units. Same with metric gear MODs. They likely neither include units as they are derived specifically from mm or inches, so are specific to the particular system.
                            #578417
                            Howard Lewis
                              @howardlewis46836
                              If it really a new machine, the supplier should supply any gears that are missing, since it has been short shipped.
                              If it "New" to you, but used,, this may help.
                              Being a recent machine, the gears are very likely to Module and 20 degrees Pressure Angle.
                              OD in mm / (Tooth Count + 2 ) = Module
                              So a 1.25 Module gear with 60 Teeth would be 77.5 mm OD.
                              Once you have found which gears are missing, you could ask WARCO if they can supply.
                              It is possible that gears from a later machine would have the same Module, width, bore and keyway.
                              #578437
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi Howard, the Warco 220 is an old lathe, I bought mine second hand way back in about 2005 and they were not in Warco's 2002 catalogue, so there's no guarantee that they will have any spares now for them, Sam could always ask of course.
                                Regards Nick.
                                #582597
                                Sam Bernard
                                  @sambernard62918
                                  Posted by Peter G. Shaw on 04/01/2022 09:21:00:
                                  Sam,
                                  Cheers,
                                  Peter G. Shaw
                                  Hi Peter,
                                  Many thanks for your response.
                                  When you swap over from turning to screw cutting I understand that you need a short tee nut and also a bush, would you mind giving me the sizes of these components? A picture of the setup in screw cutting mode would be really helpful.
                                  Ive brought some off the shelf gears that I’m modifying to fit.
                                  #582615
                                  Peter G. Shaw
                                    @peterg-shaw75338
                                    Sam,
                                    May I suggest that you use the private messaging system to send me your (or a suitable) email address. The reason is that I have, so far, turned up two photos which I believe are what you may be asking for, a word document I did some time ago on fine feed and a set of drawings which I did some years ago when I managed to break the triple pulley block on the finefeed mechanism. This drawing shows, I think, all the parts that you are asking for. It will have to be a pdf, unless you can read drawings from Design Cad Pro! Also, the measurements will be as I measured them, and I rather think that there is space for rationalisation, eg, a dimension of 4.06mm is probably meant to be 4.00mm. At least, if I was designing from scratch, I would be very unlikely to use such odd dimensions.
                                    All in all, a lot of stuff to put on the ME/MEW forum – not for any reasons of secrecy, just the practicalities.
                                    Cheers,
                                    Peter G. Shaw
                                    #659691
                                    Daniele Farronato
                                      @danielefarronato46331
                                      Buon giorno a tutti, sono un nuovo mambro e sono inesperto in materia. Sto imparando da autodidatta. Sono da poco venuto in possesso di un tornio mashtroy(warco 220) sto cercando di restaurerlo, però non ho un libretto istruzioni, ho visto che ci sono dei giochi nelle chiocciole in ottone, e non so il passo della vite senza fine. Qualcuno nel gruppo mi può aiutare? Informazioni, disegni, ecc. Ne sarei molto grato grazie
                                      #659726
                                        My computer auto translated this when I approved it this morning, for those that can't translate
                                        "Good morning everyone, I'm a new member and I'm inexperienced on the subject. I'm self-taught. I have recently come into possession of a mashtroy lathe (warco 220) I'm trying to restore it, but I don't have an instruction booklet, I saw that there are some games in the brass nuts, and I don't know the pitch of the worm. Can anyone in the group help me? Information, drawings, etc. I would be very grateful, thank you"
                                        #659728
                                        DiogenesII
                                          @diogenesii
                                          'Play in the nuts and I don't know the pitch of the screw'?
                                          ..does anyone have enough Italian to ask whether Daniele means the leadscrew or feed-screws?
                                          #659733
                                          Ady1
                                            @ady1
                                            Big worm or little worm (in italian)
                                            #659764
                                            Ady1
                                              @ady1
                                              Got a message:
                                              Buon giorno, sto cercando i passi delle chiocciole in ottone tutti e due grande e piccolo. Grazie mille
                                              Good morning, I'm looking for the steps of the brass snails, both large and small.
                                              anyone got the TPI for the leadscrew nuts pls
                                              http://www.lathes.co.uk/mashstroy/
                                              https://docs.hacman.org.uk/instruction_manuals/Warco-Lathe-220.pdf
                                              I'm guessing the main half nut is 4mm
                                              Edited By Ady1 on 10/09/2023 17:57:38
                                              #714892
                                              Daniele Farronato
                                                Buon giorno a tutti, sto cercando la controtesta per tornio warco 220, qualcuno può suggerirmi dove si può trovare? Grazie
                                                #714920
                                                peak4
                                                  @peak4
                                                  Auto Translation
                                                  Good morning everyone, I am looking for the chuck for a Warco 220 lathe, can anyone suggest where I can find it? Thank you.
                                                  Sorry, I can’t help with a chuck
                                                  Is it flange mount with bolts?
                                                  If so, I guess a plain threaded backplate attached to the chuck of your choice.
                                                  Bill
                                                  #715208
                                                  Daniele Farronato
                                                    Buon giorno, potresti suggerire qualche sito d’acquisto. Grazie
                                                    #715210
                                                    peak4
                                                      @peak4
                                                      Sorry I don’t speak Italian.
                                                      What size, how many jaws, and what is the spindle fitting?
                                                      Google Translation result
                                                      Mi spiace, non parlo italiano. Di che dimensione, quante ganasce e qual è il montaggio del mandrino?
                                                      Bill
