Tom Senior Bull Wheel Pin
Home › Forums › Manual machine tools › Tom Senior Bull Wheel Pin
  • This topic has 10 replies, 4 voices, and was last updated 8 May 2013 at 16:20 by Mike the Bike.
  • #118623
    Mike the Bike
      @mikethebike
      I have just bought a TS mill which is missing the locking pin and all other parts to lock the pulley and bull wheel.
      I would be gratefull for either a photo or drawing of the pin and the means to keep it engaged or dis-engaged. There appears to be a threaded hole about 1" from the pin hole, which I think must be for some form of locking plate.
      Thank you for helping me.
      Edited By Mike the Bike on 07/05/2013 14:13:03
      #118634
      Mike the Bike
        @mikethebike
        #12129
        Mike the Bike
          @mikethebike
          #118625
          Les Jones 1
            @lesjones1
            Hi Mike,
            There is some information in issue 156 (Autumn 2009) MEW about restoring aTom senior mill that may help you. On page 40 there is a picture of the locking pin but it is not very clear. There is also a diagram on page 42 which shows the locking pin. It shows the pin as 3/8" dia with two grooves spaced by 12 mm. I think it shows that the length between the inner groove and the end of the pin is 18 mm (the 18 mm is printed on the drawing of the pin with no demension lines.) At first I thought it was the diameter but a note says that the diameter is 3/8" I suspect the threaded hole retains a spring which engages with the grooves to retain the pin in either of its two positions. Hope this helps.
            Les.
            #118636
            Les Jones 1
              @lesjones1
              Hi Mike,
              Les.
              #118627
              MICHAEL WILLIAMS
                @michaelwilliams41215
                MikeB – lots of pictures on above web page and lots of links to other useful pages .
                MikeW
                #118638
                MICHAEL WILLIAMS
                  MikeW
                  #118808
                  Brian Wood
                    @brianwood45127
                    Hello Mike,
                    I've lost patience trying to download picture and sketch here, look in my photos for Tom Senior Drive pin, I have sketched the dimensions from my 'Junior' and taken a photo of how they are arranged, pin to spring, on the machine.
                    Release by pushing the spring away to engagethe pin in the two postions
                    I hope that helps you. the pin is soft by the way, easy to make and the spring clip would not be difficult to make up either
                    Good luck Brian
                    #118820
                    Brian Wood
                      @brianwood45127
                      Hello Mike,
                      Good luck Brian
                      #118817
                      Mike the Bike
                        @mikethebike
                        Hello,
                        Thank you Les and Michael and Brian.
                        The information you have directed me to should be sufficient to enable me to make the parts and get going. Your comments have helped as well as the photo's and sketch of the spring.
                        Once again the sum of knowledge comes to the rescue.
                        Many Thanks,
                        #118830
                        Mike the Bike
                          @mikethebike
                          Hello,
                          Many Thanks,
