Taper Pins
Taper Pins
Home › Forums › Beginners questions › Taper Pins
  • #107453
    nigel jones 5
      @nigeljones5
      Hi – Ive got a part with some tapered holes in it, but ive got no pins. The big end of the hole is about 60 thou and its 1/2" long. Do I make them, buy them? What taper will they be? What material? Do they need loctiteing in? Hope you can help. Nigel
      #6495
      nigel jones 5
        @nigeljones5
        #107457
        JohnF
          @johnf59703
          Hi, sounds to me that they are standard taper pins 1/16" dia, generally taper pins are in inches per foot but i would have to look it up its to many years ago to remeber !!! Chronos sell them for £3.60 per 10off
          Chris Trice
            @christrice43267
            Imperial sized taper pins have a 1 in 48 taper, metric 1 in 50. EKP Supplies also sell them in small quantities.
            #107471
            Pete
              @pete41194
              It really does depend on what the part is from and where and when it was built. Because there's also a metric series of taper pins too. Machinery's Handbook lists the dimensions. But a good industrial tool supplier would also list the dimensions for the taper pin reamers. You might need to make up a imperial and metric pin to see what fits the best. They do need to fit almost as well as a male Morse taper needs to fit the female bore.
              Pete
              #107480
              roy entwistle
                @royentwistle24699
                You can get clock pins from Meadows and Passmore Put m-p into google they come in steel or brass
                Roy
                #107494
                Russell Eberhardt
                  @russelleberhardt48058
                  Posted by fizzy on 29/12/2012 21:40:40:
                  No, don't use loctite. If they are a good fit they just need a light tap to hold them in place. Remember, you might want to dismantle it at some time in the future.
                  Russell;
                  #107543
                  Sub Mandrel
                    @submandrel
                    I got a good supply of taper pins from Proops and found a matching reamer at a boot sale. They work so well I'm surprised they aren't used more often. I have turned up my own pins when I have 'over reamed' the hole and they work fine.
