Taking a pair of wire cutters to a standard baseball cap
Home Forums The Tea Room Taking a pair of wire cutters to a standard baseball cap
Viewing 25 posts - 1 through 25 (of 46 total)
  • #489048
    Greensands
      @greensands
      Does anyone else have this problem when wearing the standard model baseball cap. Getting into and out of tight places such as the back seats of a car or perhaps a low greenhouse door etc wearing a cap I have found it it is all too easy to make contact with the top of ones head the results of which can be a nasty bruise or scrape.
      It might sound a sacrilegious action to take with such an iconic product but I now have got into the habit of taking a pair of wire cutters to remove the offending top-knot which is conventitonally held in position by quite a substantial metal rivet, some made from aluminium other times from steel leaving it in my opinion a much safer product to wear. Strangely enough, such an operation does not appear to affect the structural integrity of the cap in any adverse way and I feel much happier wearing it in confined spaces.
      #36011
      Greensands
        @greensands
        #489054
        Jeff Dayman
          @jeffdayman43397
          It's a serious offense in many parts of the world to remove that button, as it is a little known CIA / NSA tracking device and microphone to help them monitor and control the world's population. It's not a lightning conductor as many people in Iowa USA believe.
          It is no accident that many people in China refuse to wear baseball caps intended for markets outside China.
          But if it is bumping your head , by all means remove it. Buying a pickup truck with higher doors would save you getting out the cutters and risking spontaneous uncommanded hat disassembly.
          Probably be wise to line the hat with aluminum foil though, to prevent the "missing button tracking rays" from CIA / NSA satellites reaching your brain.
          Edited By Jeff Dayman on 03/08/2020 20:32:36
          #489056
          Paul Rhodes
            @paulrhodes20292
            Interesting libertarian information Jeff. It may explain the observed effect of wearing reducing the IQ of the wearer by 5%. However it does not explain the observation that wearing a baseball cap backwards induces a 10% reduction in IQ.
            #489064
            Sam Stones
              @samstones42903
              There must exist, irrefutable evidence to confirm that the fashion of wearing the cap back to front was a deliberate CIA/NSA ploy to ensure that the microchip embedded in the head band was closer to the wearer’s frontal lobes.
              #489066
              Jeff Dayman
                @jeffdayman43397
                Paul – is it only 10% reduction? I'm sure it is even higher if worn backwards but at an angle, the closer to 45 degrees it gets , IQ seems to fall off rapidly. Probably related to antenna symmetry….. worth investigating, I think.
                Sam – I'm sure there is such irrefutable evidence, but we will never know, it is probably stored even deeper in America's most secure vaults than the Coke formula and the Kentucky Fried Chicken recipe. Completely bubba-proof. I wish someone would adjust the gain on the chip embedded in the president's hairpiece retainer tape to tune that guy in a bit.
                #489067
                Steviegtr
                  @steviegtr
                  Due to the above information. I have just burned mine in a hot furnace. Buried the ashes in a lead container & will sink it at sea.
                  Steve.
                  #489068
                  Mike Poole
                    @mikepoole82104
                    Having never worn a baseball cap I have not experienced this problem, in the U.K. they are only really worn by kids and gang members.
                    #489070
                    duncan webster 1
                      @duncanwebster1
                      Note to wearers of baseball caps with MAGA emblazoned across the front:
                      in Nigerian pidgin maga means 'easily fooled idiot' maga
                      #489072
                      Bill Phinn
                        @billphinn90025
                        In Latin it means a female magician or enchantress.
                        Posted by Mike Poole on 03/08/2020 22:03:55:
                        I used to be averse to them too, Mike, for similar reasons, but they're very good for keeping the sun off your eyes when you're working outdoors, looking skywards or into the sun, and really need to see what you're looking at. They're also readily available and cheap, unlike more traditional British headwear.
                        #489075
                        Emgee
                          @emgee
                          I have to admit to wearing various baseball type caps, they cost next to nothing and the peek keeps the light off my glasses, without the peek reflection on my glasses makes being outdoors uncomfortable on the eyes.
                          Emgee
                          #489080
                          Jeff Dayman
                            @jeffdayman43397
                            Hi Duncan, I was not aware of the meaning of maga in Nigerian slang. But I would not suggest mentioning this fact to someone with the extra word "Krav" in front of "Maga" on their cap. If you do, you may find your limbs rearranged by the cap wearer and will have to drink coffee up your nose through a straw for about 6 weeks.
                            Enough!
                              @enough
                              Posted by Greensands on 03/08/2020 20:04:53:
                              FWIW you can get "hard-hat" baseball caps lined with a hard plastic shell. Being follicly challenged I use one if if have to crawl around under the machines/benches in the shop.
                              (Sorry to be serious for a moment) wink 2
                              #489082
                              Hopper
                                @hopper
                                It sounds like you have been wearing your baseball cap back-to-front with the peak sticking out forwards and blocking your vision of what is above your head. If you wear the cap right-way-round with the peak sticking out the back, vision will be unimpaired and you will stop bumping your head. (Of course, here in Australia, we wear ours upside down, but that's a different issue.)
                                Edited By Hopper on 04/08/2020 03:35:37
                                #489087
                                Mike Poole
                                  @mikepoole82104
                                  My youngest son was a wearer for a while, The hat of choice was the New Era fifty nine fifty which comes with a size sticker on the top of the peak, this has to be carefully removed and repositioned under the peak to protect from the rainlaughlaugh
                                  #489102
                                  Nick Wheeler
                                    @nickwheeler
                                    Posted by Bandersnatch on 04/08/2020 01:36:49
                                    They're called 'bump caps', for when you don't need a fully specced hard hat.
                                    One of our suppliers gave them out after he saw me walk into a propeller as he parked his van…. It seems I don't need a physical IQ reducer!
                                    #489103
                                    Mike Poole
                                      @mikepoole82104
                                      The trouble with bump caps or full on hard hats is that I bump my head all the time when wearing them but very rarely when bare headed. We seem very aware of where our body is, I regularly clatter my wristwatch but never hit my other wrist which is unadorned.
                                      #489104
                                      oilcan
                                        @oilcan
                                        funnily enough, when I wear my peaked cycling cap, I always think it makes me 5% smarter…….although I always have the feeling most car drivers think the opposite!
                                        #489106
                                        Danny M2Z
                                          @dannym2z
                                          I always thought that people with their baseball cap on the wrong way around had their head on backwards.
                                          That was until…………………………….I wore one at the rifle range and tried to sight in a benchrest target rifle. Had to turn it backwards!
                                          At least it's the only place that I can wear a Donald Trump 'Make America Great Again' cap and get a few admiring smiles
                                          It is surprising how many people ask me where did I obtain it and ask to borrow it for a selfie?
                                          Disclaimer – a friend bought it for me and I don't want to upset her so I only wear it to get a few bites. No way do I support the bloke!
                                          * Danny M *
                                          #489110
                                          Greensands
                                            @greensands
                                            Wearing a baseball cap has always been standard issue in my workshop but I would agree that the problem is essentially a lack of upwards vision when wearing the cap in the 'sensible' position. The only time I would select the 'idiot' position would be when using a magnifying glass for close-up work or the like where the peak gets in the way of things
                                            #489111
                                            Nicholas Farr
                                              @nicholasfarr14254
                                              Hi, I think you have all got it wrong, the button is just a red herring and the stereo microphones are actually imbedded in the peak along with micro self levelling cameras and an orientation tracker, so it doesn't matter which way you wear it, they know who you are and where you are going. wink 2 I think it's connected to the MIB (men in black) brigade. smile d
                                              Regards Nick.
                                              #489121
                                              not done it yet
                                                @notdoneityet
                                                I have to admit that I wear a peaked hat occasionally – to keep the veil, of one of my bee-suits, well away from my face. Two layers of material on one’s head can help prevent any nasty bee from stinging the top of the head, too.🙂
                                                I also wear a smooth topped hat when working under my too-low garden bird netting – a button on top would not be a good idea. Thatch is getting thin enough without losing any more.
                                                #489122
                                                Nick Clarke 3
                                                  @nickclarke3
                                                  In photography they are an excellent addition to the camera bag as they enable one to keep the worst of the sun off a digital SLR display.
                                                  But it is as a collector and occasional user of old film cameras they really come into their own:
                                                  Turned back to front to use an eye level SLR in the hot sun, facing forwards to keep a focussing cloth from sagging when using a large format camera and most usefully of all – forwards again – to stop a waist level finder from filling up with water when it is raining.
                                                  #489195
                                                    Please can we avoid politics creeping into this thread, and remember to be respectful to each other?
                                                    Thanks,
                                                    clogs
                                                      @clogs
                                                      just turned 71 and wore one for the first time a week ago……very strange…….
                                                      when I lived in the UK it was a beanie or a full on waterproof hood…….
                                                      sure makes a change to be in the sun virtually everyday…..thank goodness…..
                                                      the main reason for old people shrinking is the wet conditions experienced most of the time in the UK……
                                                      mind u plants wither in the sun…..hahaha……..no easy way to get old gracefully I guess…………
