steel grade for high strain tools ?
Home Forums Beginners questions steel grade for high strain tools ?
  • #119328
    Rich2502
      @rich2502
      i want to make some gear and bearing pulling tools which look like they're normally drop forged, I have plenty of mild steel, could this be hardned to near the same toughness ? or would i need another grade steel ?
      while you can buy the tools cheap off ebay,which snap, the real ones like Sykes Picavant are not cheap.
      #119340
      Rich2502
        @rich2502
        #119349
        Rich2502
          @rich2502
          #6699
          Rich2502
            @rich2502
            #119330
            MICHAEL WILLIAMS
              @michaelwilliams41215
              Hi Richard ,
              There is no way of increasing the toughness of mild steel by heat treatment . You can compenstae for weakness of material to some extent by using thicker section , reinforcement or by welding on bits of better material in some places .
              There are specialist steels available for you purpose but two readily available materials which will probably do all you want are gauge plate and old spanners .
              The properties of gauge plate are well known and the material can be heat treated for toughness or hardness without to much difficulty .
              Spanners are made from particularly tough steel and you can usually buy a sackful for a few pounds at boot sales . Not usually nescessary to heat treat any more .
              Regards ,
              Michael Williams .
              #119342
              MICHAEL WILLIAMS
                Hi Richard ,
                Regards ,
                Michael Williams .
                #119350
                MICHAEL WILLIAMS
                  Hi Richard ,
                  Regards ,
                  Michael Williams .
                  #119332
                  Jeff Dayman
                    @jeffdayman43397
                    AISI 4140, 4340, or one of the 9300 series steels will make very tough and strong pulling tools particularly if forged and then tempered to low/mid hardness.
                    Unless the parts you want to pull off are very small, forget carburized mild steel.
                    Oil and water hardening tool steels will often crack if used for such pulling tools with a cantilevered load.
                    JD
                    #119343
                    Jeff Dayman
                      @jeffdayman43397
                      JD
                      #119352
                      Jeff Dayman
                        @jeffdayman43397
                        JD
                        #119338
                        Raymond Anderson
                          @raymondanderson34407
                          Hi Richard,
                          Jeff's 2 suggested steels [AISI 4140, AISI 4340] are better known here[if you are in the UK] as EN19 ,EN24
                          any of the 2 would suit just fine. Raymond.
                          #119347
                          Raymond Anderson
                            Hi Richard,
                            #119357
                            Raymond Anderson
                              Hi Richard,
