So where am I going wrong
Home › Forums › Beginners questions › So where am I going wrong
  • #137442
    Oompa Lumpa
      @oompalumpa34302
      I am trying to replicate a small – 22mm long 3mm diameter – adjusting screw.
      Left Hand Thread. Split Die bought from RDG – Not UK Made
      I have made it twice now, both times they made it to the scrap bin!
      I am turning it from a piece of EN3B, down to 2.9mm the first time 3.1mm the second time. and both times I ended up with something that vaguely resembled a thread, about 2.5-2.6 mm in diameter and it fell through the threaded hole both times.
      Any pointers gratefully received. I was thinking maybe the steel was too soft?
      graham.
      #6969
      Oompa Lumpa
        @oompalumpa34302
        #137445
          Posted by Oompa Lumpa on 09/12/2013 19:17:37:
          graham.
          Is that the steel teh die is made of or the EN3Bsmile p
          I did have similar problems with a 5/8×40 die from RDG a couple of months back and ended up screwcutting it on the lathe
          J
          #137447
          blowlamp
            @blowlamp
            A problem I've experienced is that either one or more of the securing-screw holes in the die-holder, or the 'dimples' around the die are not aligned, so when they're tightened down they tend to distort the die and make it cut a horrible thread. It might be worth your while to check it out.
            Martin.
            #137448
            Oompa Lumpa
              @oompalumpa34302
              Posted by JasonB on 09/12/2013 19:32:51:
              graham.
              J
              I did think it just might be the Die Jason
              Snag is that it is 3mm AND left hand thread.
              Bugger.
              graham.
              #137453
              Oompa Lumpa
                @oompalumpa34302
                Posted by blowlamp on 09/12/2013 19:45:15:
                Martin.
                This is why I love this place. Great thinking Martin and certainly a possibility.
                I was just thinking myself there – always a danger – could it be that the die is also faced? What I mean is, there is no lead in on one side?
                graham.
                #137454
                Ady1
                  @ady1
                  I got my best results by roughing most of it out on the lathe, then finishing with a die
                  If I wanted a nice tight thread, I never used a die, the ones I have always overcut a bit too much
                  No doubt they cut "within acceptable tolerances", but still too much for the more precise scenarios
                  Edited By Ady1 on 09/12/2013 19:55:47
                  #137455
                  old Al
                    @oldal
                    EN3B will tear a bit, but you should get better than you have done.
                    Are you using any tapping fluids.
                    Are you using a tailstock dieholder, if not are you using something behind the die to keep it square.
                    EN3B allows you to have a second stab at it, so you can open up the die, take a cut and then close down the die for a second cut. Don't try this in stainless.
                    Is the die, carbon steel or HSS
                    #137466
                    Oompa Lumpa
                      @oompalumpa34302
                      It's not cutting within any tolerance Ady, it's turning the screw down from 3.1mm to 2.5 mm and unable to function as a screw..
                      Al, yes I use cutting fluid and a Die stock holder. Rather, I hold the Die in a Die stock and then against the tailstock, it works well and I have always done it this way with 100% success. I suspect the die is carbon steel. Also tried the light cut/heavier cut scenario you describe.
                      Doyou think it's worth buying another die? Left hand – 3mm?
                      graham.
                      #137469
                      jason udall
                        @jasonudall57142
                        Split die. Are you spreading the die.?
                        Left hand tread. Just possible you forgot and turned wrong way ?
                        Also does your chuck unscrew..
                        Edited By jason udall on 09/12/2013 20:50:29
                        #137479
                        Tony Pratt 1
                          @tonypratt1
                          From my own experience these budget dies do have 'issues', they do a job but not always very well. If you turned the job the wrong way as suggested the left hand die wouldn't go on. Try turning to 2.9 mm and have a nice 45 deg. chamfer on the end, open up the die for the first pass, hold it in a tail stock die holder if possible, use cutting oil and not too fast on the spindle speed.
                          Tony
                          #137483
                          Versaboss
                            @versaboss
                            Posted by Oompa Lumpa on 09/12/2013 20:37:50:
                            Hmm, Graham, did you forget to let the lathe running backwards for the left hand thread??? devil
                            Hansrudolf
                            #137484
                            old Al
                              @oldal
                              I had something from Tracy Tools do something odd once. They exchanged it straight away. Good customer service. See what RDG say before shelling out on another.
                              #137512
                              Gordon W
                                @gordonw
                                With a small dia. thread there is a lot of metal to bend when opening the split. It may be that cutting grooves, with a thin cutting disc, will allow the die to open a bit more. I've done this with some success, but not if the die is going to be returned!
                                #137537
                                Oompa Lumpa
                                  @oompalumpa34302
                                  This:
                                  "turning to 2.9 mm and have a nice 45 deg. chamfer on the end, open up the die for the first pass"
                                  and This:
                                  "and shouldn't be overtightened. In fact, I only ever use one screw, not all three"
                                  worked for me.
                                  Opening the die – quite a bit actually – has stopped it 'overcutting' the small rod i turned. I now have a workable thread. Bit of a result really as I really didn't want to be shelling out for a new HSS die and hoped the steel one would work. It can now go into the drawer for the next millenia to come along when I might need it again.
                                  This is the problem when you are spoiled with first class kit and you buy something "on the cheap" just to get you away on a job. I really should know better. Not to worry, something else I have learned. Bit of a result really.
                                  graham.
                                  #137538
                                  Anonymous
                                    Posted by Oompa Lumpa on 10/12/2013 15:30:27:
                                    graham.
                                    If it was mine it'd be going straight into the bin. thumbs down
                                    #137539
                                    Rik Shaw
                                      @rikshaw
                                      In a perfect world do this:
                                      Put a "good" split die in the holder and use the centre screw to slightly spread the die. Cut the thread. Use a die nut to remove the last little bit down to size. Works for me every time (Where I have a die nut the correct size that is).
                                      Rik
