Hi Ron,
Beginners should steer clear of oxy-gas systems. The heat is too concentrated and you may find it difficult to heat the joint properly to achieve the necessary capillary attraction required to attain the complete penetration of the alloy and strong leak free joints.
Go for propane, it is cheap, effective, efficient and versatile. Get a variable 1 – 4 bar regulator. This will set you up to produce between 84 and 0.25 kw of heat from your burners. The best in the range is undoubtedly Sievert.
Visit the website for more detail to help you to make a informed decision.
Keith
