Hello all, I am recovering from a hip operation [lucky to get it done] so I will not be able to get in the shed for a few weeks or so. I have some Dormer 9, 8, 7 mm slot drills that just need a few licks with a grinding wheel for them to be serviceable. I would not ask this but would try but as said cant do it at the moment.
I have partly made Harrold Hall grinding rest but thought this idea could be a quick grind. 12mm square steel about 15mm long drilled to take the slot drill at a 8 deg angle, a slot and a grub screw to hold . Then put it in the toolpost on the lathe clock it square and have a spacer on the back of the tool holder so when it turned over 180 deg its in the same position. Then true up the grinding wheel on a spigot in the chuck, line it all up and take a few licks off each cutting edge.
As I have said sitting at home thinking, otherwise would not have posted this.
Thanks Bob
