On
21 September 2026 at 23:44 Bazyle Said:
…This locks/unlocks the whole plate allowing it to be rotated to the next hole in the back
…this also allows compound indexing using two hole counts simultaneously.
…although my 4in Elliott has it I have hardly ever seen others.
If you have one with the same feature, it might be useful to show a numerical example of its use. The Elliott manual does not contain tables for this feature.
On the ebay one to which you link, the rear plunger is at a fixed radius. That means it works with (only) one hole circle on the back.
Perhaps you could say with which hole circle your own one aligns.
In the Elliott manual, they call the analogous item ‘dividing plate lock’ (20a, 20b page 38 & 39, also item k page 33, but never referenced in the text).
I think both the Brown & Sharpe and Cincinnati ‘Treatise(s) on Milling’ (from the Internet Archive) have discussion of this feature.
See this post, which is one of Marv Klotz’ programs to do this work. Someone recently posted here on the forum about an updated version of these.
https://www.homemadetools.net/forum/compound-indexing-41406
