Quality Control ?
Quality Control ?
Home › Forums › The Tea Room › Quality Control ?
  • #36078
    J Hancock
      @jhancock95746
      Battery can opener………..as seen on TV
      #497565
      J Hancock
        @jhancock95746
        Not this one !
        Arthritis overtaken my ability to use a manual can opener so this 'one touch' the obvious solution.
        Brand new, out of box, new batteries inserted, press button………….nothing.
        Close look reveals +ve teat on both batteries 0.030" short of connection.
        Of course, no problem to cure for 'us' but I wonder how many have been returned.
        #497586
        Ian Parkin
          @ianparkin39383
          So was it a battery problem or the can opener?
          batteries now seem to have a shorter +ve teat than they used to
          #497590
          Gray62
            @gray62
            I have found this problem to be more apparent with Duracell batteries. A number of my granddaughters toys will not work with Duracells but work fine with other makes. Duracell batteries have a much shorter +ve terminal than other major brands
            #497592
            J Hancock
              @jhancock95746
              The battery teat is guided into a slot which has the +ve plate ready for the battery end to make contact with it.
              No AA battery I have has a long enough teat to reach the fixed plate.
              The -ve contact is the spring pushing the battery into place hard up against the slot.
              It was easy enough for me to build the two +ve fixed plates up with 0.040" of solder but 'we' are not the
              'average' consumer.
              Device works really well.
              #497594
              larry phelan 1
                @larryphelan1
                Been there, done that !!
                There is a lot to be said for cans with ring pulls. Yes I know they cost a bit more [dont see why this should be, but it is ] I got a pain-in-my-arse trying to open cans of anything long ago [I wish I could join things together like they do ] so now I tend to buy just ring pull tins.
                This may be part of what they call "Progress"cheeky
                #497601
                J Hancock
                  @jhancock95746
                  You've just touched another 'rant' I have.
                  Only last week I dropped a can of Carling lager as I was taking it out of the 'fridge'.
                  A millisecond later it was passing my ear on the way to the ceiling , propelled by a jet of Carling coming out of the ring pull area.
                  As confirmed by the 'air accident ' investigation afterwards.
                  My do they have that ring pull area controlled to fine ' just ok' limits.
                  #497603
                  Mike Poole
                    @mikepoole82104
                    It always seems to be touch and go whether the ring pull opens the can or my finger nail lifts from my finger, we have a gadget for ring pulls but I never remember to use it.sad
                    #497605
                    Dave Halford
                      @davehalford22513
                      How come you don't end up with just the ring pull dangling from your finger?
                      #497698
                        Posted by J Hancock on 24/09/2020 16:57:52:
                        Serves you right for drinking fizzy lager instead of nice warm, flat beer!
                        cheeky
                        .N.
                        #497713
                        Dave Smith 14
                          @davesmith14
                          And in cansthinking
                          #497714
                          Dave Smith 14
                            @davesmith14
                            And in cansthinking
                            #497735
                            J Hancock
                              @jhancock95746
                              What I did find out, dried lager makes a good non-slip floor finish.
