passenger car wheels
Home › Forums › Beginners questions › passenger car wheels
  • #6511
    Joseph Ramon
      @josephramon28170
      #108287
      Joseph Ramon
        @josephramon28170
        Is it feasible to make passenger car tyres from thick tube and alloy wheels within?
        Joey
        #108375
        nigel jones 5
          @nigeljones5
          Is this a joke?
          #108376
          Andyf
            @andyf
            I think Ramon may mean railway passenger cars, or coaches, using alloy wheels fitted with tyres machined from slices of thick steel tube.
            Andy
            #108402
            Sub Mandrel
              @submandrel
              If you mean fitting steel tyres to alloy wheels, I don't see why not. Is there a particular reason for going down this route (I ask as I have a half-started driving car may have some tube I could use for tyres, but I'm not sure if I do what I could use for wheels).
              Jeff Dayman
                @jeffdayman43397
                Don't forget to consider the different thermal expansion coefficients for aluminum vs steel or iron. On a cold day, the alum will contract more than the steel, and on a hot day it will expand more than the steel. If this is planned for in the fastenings and fits, it should not be a problem, but do your math before building…..or make the whole wheel from steel and worry no longer.
                Keep in mind too the rough rule that aluminum is 1/3 the weight of mild steel but is also 1/3 the strength of mild steel.
                JD
                #108410
                magpie
                  @magpie
                  Fizzy, i think Joey is perhaps thinking of cutting a short length of a large diameter thick wall tube, rather than wrapping a piece of tube round a hub !!!!!
                  Cheers Derek
                  #108414
                  nigel jones 5
                    @nigeljones5
                    very spurious!!
                    I still dont like spiders!!
                    #108418
                    Bazyle
                      @bazyle
                      You would also need a different material for the centre bearing.
                      Potentially with reasonable use the outer rim will get stretched by effectively being continually cold rolled and become loose unless a hard steel is used and shrunk on. Perhaps you were thinking of cast alloy spokes. If just to avoid expensive castings or gettting large steel discs cut perhaps welded plate centres would do.
                      #108428
                      Joseph Ramon
                        @josephramon28170
                        Sorry for causing confusion. I have the material to hand to make steel tyred wheels with aluminium hubs on steel axles. The warings about it coming loose sound feasible, so I will rethink.
                        Thanks
                        Joey
                        Edited By Joseph Ramon on 11/01/2013 11:32:45
                        #108429
                        Anonymous
                          Posted by Jeff Dayman on 10/01/2013 22:14:53:
                          It's roughly right, but not the whole story.
                          The density of iron is about 7850kg/m^3, aluminium is about 2710kg/m^3, so as correctly stated aluminium is about a third as dense as steel.
                          A typical tensile strength for EN1A is 400MPa, for pure aluminium (1050) about 130MPa, depending upon temper. So pure aluminium is only a third of the strength of EN1A. However, pure aluminium (1050) is unlikely to be available in any form other than sheet, as it bends easily without cracking, but machines badly.
                          The inners of the wheels would most likely be made from an aluminium alloy. For a common aluminium alloy, 6082, with a mid-temper, tensile strength is around 260MPa, so more like two thirds the strength of steel. For an aircraft spec aluminium alloy, 7075 with a T6 temper, tensile strength is around 500MPa, so stronger than steel. If it wasn't then we'd make aeroplanes from steel as it would be cheaper. smiley
                          #108469
                          Sub Mandrel
                            @submandrel
                            This has got me wondering if I still have the body shell from an old mini-lathe motor? It might provide tyres/rims to suit my driving car if my welding is up to adding steel centres.
