Need help on sizes
Need help on sizes
Home › Forums › Locomotives › Need help on sizes
  • #1813
    wendy jackson
      @wendyjackson
      #407953
      wendy jackson
        @wendyjackson
        hi, I need some help on nut and tube sizes. The drawings state that I need the following. 3/8x32t for 1/4 pipe. 5/16x26t for 1/8 pipe and 5/16x 40 or 32t for 5/32 pipe. I can’t find any place that sells these sizes, i can make the nuts, it the tube ends I am worried about. These are for the blower and cylinder fittings inside the smoke box. What is the best way forward on this. Thanks.
        #407959
        I.M. OUTAHERE
          @i-m-outahere
          Try model engineering supply stores possibly under Model Engineer (M.E) tap set , pretty sure 32 and 40 tpi are M.E pitches or possibly UNEF .
          #407966
            All obtainable from the usual ME suppliers, try Tracey for starters 40 & 32 ME 26tpi
            What are you worried about on the tube ends? just silver solder a nipple (aka ferrule) on the end.
            Edited By JasonB on 06/05/2019 16:34:15
            #407976
            wendy jackson
              @wendyjackson
              Thanks chaps
              #407977
              wendy jackson
                @wendyjackson
                Thanks chaps
                #407985
                Howard Lewis
                  @howardlewis46836
                  32 and 40 tpi are the usual Model Engineer pitches, if Whit form.
                  Taps, Dies and Nuts should be available from M E suppliers, such as Tracy Tools or Tap and Die Company for the Taps and Dies, and A J Reeves, MACC, Maidstone Engineering, etc for the nuts and cones.
                Home › Forums › Locomotives › Topics
