Myford Super 7 questions
Home Forums Help and Assistance! (Offered or Wanted) Myford Super 7 questions
  • #793553
    Simon Williams 3
      @simonwilliams3
      Interesting article incorporating some fancy footwork, but the OP’s first sentence says he has a metric Myford.  I have seen it written here many’s the time that there ain’t no such animal, all S7’s are imperial by dint of having an 8 TPI leadscrew.
      I suppose it’s possible that the OP has something which has been “aftermarketed” but the question remains.
      On what evidence is this identified as a metric machine?  If it is such, how did it happen and is it an interesting oddity or evidence that Myford did have an export department?
      Regards Simon
      John Haine
        @johnhaine32865
        Myford sold the S7 in a metric version (which I bought), the X-slide LS is truly metric but the Z axis is 8 tpi.  However the OEM Z-axis handwheel is graduated as 0 – 3.15 mm with an extra slightly wider gap at the end.  So you can use the machine as true metric as long as the Z axis cut is limited to less than that, if it’s more you need to do some fancy footwork!
        #793568
          On Simon Williams 3 Said:
          […] On what evidence is this identified as a metric machine?  If it is such, how did it happen and is it an interesting oddity or evidence that Myford did have an export department?
          I don’t recall the date, but I have a vivid recollection of one visit to to Beeston when the clever contraption for graduating tailstock barrels in either Imperial or Metric was on display … so they were obviously making some metrication effort.
          davp1971
            @davp1971
            <p style=”text-align: left;”>hello, the markings on the handwheels are metric. i checked this with a modified caliper attached to the slide. apparently there are articles written about this question. leadscrew is therefore always imperial.</p>
            Myford Metric Lathe Leadscrew
