Tool post drill?
Tool post drill?
Home › Forums › Workshop Tools and Tooling › Tool post drill?
Viewing 8 posts - 26 through 33 (of 33 total)
  • #802696
      On Juddy Said:
      https://www.aimtools.co.uk/collections/power-tools/products/7-66
      Found out how to paste a link, I learnt something !!!
      Thanks for posting it  … The ‘professional’ version on the same page looks particularly useful !
      Robert Atkinson 2
        @robertatkinson2
        I Found the battery drill motor / gearbox / chuck
        Bosch-motor-PSR
        It’s from a Bosch PSR 9.6 drill. The silver bail bar changes the gearbox ratio. You also have torque limiting which is useful for tapping.
        Robert.
        #802834
          As a not so slight digression from the opening question … some participants might like this: https://plumier.org/overhead-drives-part-1/
          Edit: also some useful notes, here:
          http://otbok.info/index.php?n=Main.OverheadDrive
          #802839
          duncan webster 1
            @duncanwebster1
            Bosch-motor-PSR
            Robert.
            If it’s as good as my Bosch garden strimmer I’d save yourself the heartache, put it straight in the bin.
            #802856
            Robert Atkinson 2
              @robertatkinson2
              It did sterling service as a pistol drill until the nicad batteries died. It will live on…
              Robert.
              #802883
              bernard towers
                @bernardtowers37738
                S11A5872The epicyclic gear train can come in handy as well, this ones attached to the saddle hand wheel on a peatol so you can creep up to the numbers.
                #802910
                David Riley
                  @davidriley61024
                  As does this Brushless Motor version.    https://www.aimtools.co.uk/collections/grinders/products/101740
                  #802914
                  Andrew Tinsley
                    @andrewtinsley63637
                    I doubt if the die grinder will operate at sensible speeds for drilling and if it does I suspect that torque will be lacking. I would be delighted if it does, but I am reluctant to spend £40 plus to find out.
                    Having searched through my dead NiCd battery drills, I have found a couple of 18 volt units that resemble the all in one set up shown by Robert with his Bosch drill. These look a much better bet, so I will do the necessary work to make a tool post drill,
                    Andrew.
