Myford ML4 backgear disassemble
Home › Forums › Workshop Tools and Tooling › Myford ML4 backgear disassemble
  • #417959
    Stan Holmes
      @stanholmes87755
      Hi
      I'm restoring a ML4 rusty lathe and would like to know how the backgear comes apart. Does the cam bolt push out towards the tailstock? or is it screwed in? I have found two grub screws and have removed them and the main nut.
      Stan
      #19397
      Stan Holmes
        @stanholmes87755
        #418136
        Brian Wood
          @brianwood45127
          Hello Stan,
          I'm sorry to be late in reply to your question, I have only just seen it. From fading memory now, I recall that the backgear cluster that fits onto the eccentric that is used to swing it into and out of engagement is retained on it's shaft with a broad washer and countersunk screw, fitted to the 'motor' side.
          Remove those and slacken the nip bolt that proves an adjustable grip to the shaft in question [to give it some resistance to turning], the shaft should then withdraw towards the tailstock end of the lathe.
          I have a new and unused 65 tooth bull wheel available to fit the main spindle, teeth often get broken off those and they are no longer available as spares from Myford. If you need one, send me a personal message (PM)
          Good luck with the restoration
