Motorcycle General Discussion
Home › Forums › Related Hobbies including Vehicle Restoration › Motorcycle General Discussion
Viewing 25 posts - 651 through 675 (of 1,161 total)
  • #376797
    Windy
      @windy30762
      A bit of my whittling today a lot more to do
      #378830
      Windy
        @windy30762
        Not so much about motorcycles but saw an impressive 125cc single cylinder GRM two-stroke powered hydroplane at Coniston speed week.
        It broke National and World records for its class 84mph one way then 85mph return.
        GRM make single cylinder, two cylinder and four cylinder two stroke outboard engines.
        Am reminded of the Konig that was converted to racing sidecar use.
        I said to my friend Roger it looks like you could make one in a home workshop.
        Some links to GRM
        http://www.grmracing.com/
        Windy
          @windy30762
          Yesterday was talking to two fellow motorcycle speed record nuts hopefully next year a Gem gas turbine streamliner will be tested.
          Friend Graham should be giving a talk at PEEMS club early next year about his steam rocket bike a work of engineering excellence.
          Myself finished last night my crankshaft aligning with detachable straight edges for balancing jig.
          The base feet and straight edges can be adjusted for levelling.
          Apart for £2 for shims everything else was from my spares box the 20mm ally was donated by another speed enthusiast.
          Crankshaft aligner and  balancing
          Crank aligner
          Edited By Windy on 29/11/2018 13:56:46
          #383069
            Gone on Paul, write it up
            #383081
            ronan walsh
              @ronanwalsh98054
              Lovely work Windy, please show and tell us more about it.
              #383084
              Bob Rodgerson
                @bobrodgerson97362
                I made the crank cases, inner and outer ignition timing chain cover for this 350cc OHC engine from solid on a small round column Axminster mill a few years back.
                Edited By Bob Rodgerson on 30/11/2018 17:07:59
                Edited By Bob Rodgerson on 30/11/2018 17:08:59
                #383098
                ronan walsh
                  @ronanwalsh98054
                  Lovely work Bob, for next weeks project, you can whip yourself up a manx norton engine.
                  #383103
                  Windy
                    @windy30762
                    Amazing what can be done Bob in a home workshop
                    #383104
                    Windy
                      @windy30762
                      Posted by ronan walsh on 30/11/2018 16:48:41:
                      The crankshaft aligner or the crank on it.
                      #383128
                      Bob Rodgerson
                        @bobrodgerson97362
                        Hi Windy,
                        within reason I don't think there is much that cannot be made with simple machinery in the home workshop. It takes time and as you will know you have to plan the sequence of operations otherwise you can engineer yourself into a corner you can't get out of.
                        I have got CNC capability now which is fantastic for generating complex shapes. I have just started a restoration of two Humber 350cc Motorcycles, an OHV and an OHC. Hopefully I will get one finished next year.
                        #383134
                        thaiguzzi
                          @thaiguzzi
                          Posted by Windy on 29/11/2018 13:49:39:
                          Crank aligner
                          Very nice.
                          I presume alignment is on the top portion with the knife edges, and the balancing done below on the 2 pairs of brgs?
                          Many years ago, we did static balancing on our knife edges too.
                          Bob R – lovely work on the pre unit single.
                          #383171
                          Windy
                            @windy30762
                            Posted by thaiguzzi
                            Very nice.
                            The bearings are mainly for aligning the pressed up crankshaft similar to a Alpha-Tru aligner the straight edges for balancing.
                            alpha tru
                            #383285
                            thaiguzzi
                              @thaiguzzi
                              Posted by Windy on 01/12/2018 12:03:21:
                              Posted by thaiguzzi
                              Very nice.
                              alpha tru
                              Thanx for that. And yes please, i would like to buy an Alpha-Tru for 11 Pounds and 10 Shillings please…
                              #383409
                              JimmieS
                                @jimmies
                                Have we seen this already? Sorry but memory now not as good as I think.
                                Jim
                                duncan webster 1
                                  @duncanwebster1
                                  So having found that it is out of true what do you do? Just hit it with a lead hammer, or do you scotch one side with a block to prevent it rotating?
                                  This is probably becoming a lost art as Japanese bikes seem to last forever (I will now go and wash my mouth out)
                                  #383420
                                  not done it yet
                                    @notdoneityet
                                    Posted by duncan webster on 02/12/2018 19:13:49:
                                    Mine didn’t. It cost me £26.10s for a new crank for my Honda twin, back in 1969! Hate to think how much they are these days! It was likely the gearbox failure that precipitated the crank failure at ~21k miles, but the rod bearings were already at, or outsde, the service limits laid down (4mm rock at the small end?). No gaskets needed between the top and bottom crankcase/gearbox halves, mind – and no leaks afterwards.
                                    #383426
                                    Windy
                                      @windy30762
                                      Have seen video of one repairer having a stout upright fixed steel bar with probably a lead block on top just banging the offset flywheel on it a recommended way in some books.
                                      #384134
                                      Windy
                                        @windy30762
                                        Just been notified of my friends machine in Performance Bikes magazine.
                                        Edited By Windy on 06/12/2018 13:02:26
                                        #384140
                                          Posted by Windy on 06/12/2018 13:01:55:
                                          That's mighty impressive
                                          … Hope it goes as good as it looks !!
                                          JimmieS
                                            @jimmies
                                            #387956
                                            JimmieS
                                              @jimmies
                                              Perhaps build a model Bultaco this year?  Click on the left arrow to see the finished build.
                                              https://www.facebook.com/photo.php?fbid=232707467232422&set=a.232702647232904&type=3&theater
                                              Edited By JimmieS on 28/12/2018 15:49:22
                                              Edited By JimmieS on 28/12/2018 15:52:51
                                              #394299
                                              JimmieS
                                                @jimmies
                                                Anyone with information on this project?
                                                Emgee
                                                  @emgee
                                                  Posted by JimmieS on 28/12/2018 15:48:13:
                                                  **LINK**t
                                                  Superb craftsman workpieces, many very intricate parts made to scale, well worth viewing.
                                                  Emgee
                                                  #395113
                                                  Windy
                                                    @windy30762
                                                    It was PEEMS first club meeting of 2019 and what a treat for speed enthusiast members.
                                                    This small club was packed with members and guests many from the speed scene for my friend Graham Sykes Steam Rocket Bike talk.
                                                    Grahams Wife has a wealth of knowledge on this creation and was also involved in making the pressure vessel insulation blanket apart from other things.
                                                    Amongst the guest were previous talker Becci Ellis fastest women and others that have done fantastic speeds at Elvington, Pendine and other venues including the TT.
                                                    PEEMS has such a variation of interests that was the main reason why I joined years ago.
                                                    2019_Graham Sykes talk on force of nature rocket bike
                                                    Edited By Windy on 07/02/2019 08:59:58
                                                    Edited By Windy on 07/02/2019 09:13:45
                                                    #395116
                                                    Pete Rimmer
                                                      @peterimmer30576
                                                      I’ve been well north of 200mph on my home built bike without really worrying about it but the thought of swinging a leg over that monster scares the hell out of me. Fair play to the guy who rides it.
                                                      Edited By Pete Rimmer on 07/02/2019 09:34:39
