Motor rotation
Motor rotation
Home › Forums › General Questions › Motor rotation
Viewing 5 posts - 76 through 80 (of 80 total)
  • #311794
    sean logie
      @seanlogie69385
      Posted by JasonB on 13/08/2017 13:34:00:
      This is what you want, a couple of short bits of wire stripped at either end.
      Much appreciated Jason vfd up and running .
      Sean
      #311818
      Martin Cargill
        @martincargill50290
        Good to hear that its all running. How much metal have you machined this afternoon?
        The wire links that you fitted can be used for an emergency stop function. Give me a shout if you decide you want to fit one.
        Martin
        #311836
        sean logie
          @seanlogie69385
          Man this old mill makes me smile . Cut my first chips this afternoon and I’m delighted , next is to suss out how to save the setting on the vfd because I lose them every time I turn off the power . And also need to get the variable speed function up and running .
          Sean
          #311843
          Martin Cargill
            @martincargill50290
            Sean.
            It's probably worth building a separate control pod that you can mount on or beside the machine. The ventilation slots on invertor drives are not set up to cope with swarf and a piece in the wrong place would kill the drive.
            A simple pod with go, stop(and/or emergency stop) and a speed control would be easy to set up.
            Martin
            #312983
            sean logie
              @seanlogie69385
              Posted by Martin Cargill on 13/08/2017 19:55:08:
              Sean.
              Martin
              Thanks Martin , I think I'd struggle with that . Will check it out none the less .
              Sean
              Edited By sean logie on 20/08/2017 10:38:26
