Hello everyone,
Hope you’re doing well. I have a Emco FB-2 clone that I want to design a power feed solution for but my mill table doesn’t have the threaded holes on the side. I can choose to just use my own hole pattern but I would be nice to have the “correct” hole pattern from an actual Emco machine. This way I can make a kit if it works out or just make plans that other people can use if they want to have a similar solution. Please see below the dimensions needed.
Would be very grateful for any help here. I work as a mechanical designer so if someone gets me the right dimensions I’m able to help with some part that needs a drawing or so in return.
Many thanks. / Jim
