ML7 feed screw wear
ML7 feed screw wear
Home › Forums › Workshop Tools and Tooling › ML7 feed screw wear
  • #406462
    Brainsparks30
      @brainsparks30
      Having got an understanding of Gib strips and correct set up, I noticed my cross slide and compound slide feed screw nuts are worn, the cross slide has a little play and the compound quite a lot.
      Can I replace the nuts and be ok, or must the screws be changed as well?
      Would the Arc Euro Trade bearing mod fix things cheaper?
      #19318
      Brainsparks30
        @brainsparks30
        #406463
        Grindstone Cowboy
          @grindstonecowboy
          Have a read of this thread **LINK**
          #406465
          Mark Rand
            @markrand96270
            As well as the linked thread, the nuts are a 'consumable' item. They were originally Mazac/Zamac/zinc alloy and wore in preference to the feed screws. They are an easy, cheap replacement and worth doing before you replace the screws themselves, but the cost of the complete screw+nut assembly is cheaper than the original Myford Beeston parts were.. The Myford/RDG web site has them listed.
            #406479
            not done it yet
              @notdoneityet
              The decision on whether the screw and nut needs replacing should be based on backlash readings at different points along the screw.
              Also depends on your subjective “little” and “quite a lot”. There will always be “a little’ backlash. But there should be no end-float from other causes.
              #406484
              Douglas Johnston
                @douglasjohnston98463
                Just had a look at the Myford/RDG prices and have to say the word "cheap" did not come to mind, but perhaps that says more about me than anything else. Over £400 for a topslide , good grief you could buy a whole Chinese lathe for that.
                Doug
                #406488
                Hopper
                  @hopper
                  Plenty of good used topslides on eBay for about an eighth of that amount. They are not a high-wear item so a safe bet to buy used.
                  #406547
                  Peter Sansom
                    @petersansom44767
                    For power crossfeed on the S7 you need to purchase the nut/screw assembly, otherwise you can just purchase the nut, unless it has worked hard in an industrial environment. My S7 was 25 years in an industrial setting, I replaced the nuts when i acquired it.
                    Everything else can usually be fixed by adjustment
                    #406578
                    Dennis Pataki
                      @dennispataki22631
                      Keep in mind that a worn feed screw will affect the accuracy of movement as shown on the graduated dial. This is most noticeable over a long distance of movement due to wear differences in the screw threads.
                      A worn nut will only affect the backlash due to excess clearance between the screw and nut.
                      #406621
                      Hopper
                        @hopper
                        There is also the old dodge of cutting the threaded section off the screw, turning it round endwise and re-attaching it with a suitable spigot pin and silver solder. This moves the worn section to the least used end of the leadscrew. Works best with the main carriage leadscrew but not sure where the cross-slide nut rides on the S7. If its in the middle then obviously no advantage to be gained but if its at one end could be worth doing if the screw is badly worn.
                        #406639
                        Howard Lewis
                          @howardlewis46836
                          Only changed the worn nut on the Cross Slide on my ML7 when I had one.
                          Although, eventually did upgrade to the long Cross Slide and Leadscrew.
