Minnie Gears
Minnie Gears
Home › Forums › Traction engines › Minnie Gears
  • #2690
    John Shepherd
      @johnshepherd38883
      #52431
      John Shepherd
        @johnshepherd38883
        I am in the process of building a 1″ scale Minnie and have just machined the parts for the crankshaft and first shaft gears. The original article says to silver solder the gears and the fabricated keyways but I was wondering if Loctite 628 or similar would do the job?
        I have nothing against silver soldering but for this job I thought that perhaps Loctite would overcome the problems of cleaning up and there would be no trace of solder to be seen.
        As I have no previous experience of using Loctite other than the thread lock types, any advice or comments would be welcome.
          My only reservation would be that there is no keyway cut into the actual gearwheel so all  the load will be applied through the joint which may be asking a bit much of the loctite. If you are just going to run on air then its unlikely to be an issue but if you are steaming under load?
          A soft pencil (2b or similar) will leave a line that the solder should not flow over and you can always mount the soldered assembly onto a mandrel and take a light skim off to true things up and remove any excess solder.
          I solderd my minnie and by the looks of things took a skim off but that was a while ago when my soldering was not as neat as it is now.
          Jason
          #52446
          John Shepherd
            @johnshepherd38883
            Jason
            Thanks for you reply – looks like silver soldering it is. I have no aversion to  soldering but I was just exploring new methods of doing things and what you say makes sense.
            Thanks also for including the photograph lnk , it is helpful to show how mine should (hopefully) look .
            regards
            #52447
              If they are of use there are a few more pics of my engine towards the end of this album, also some close ups of the damper hinge I took for someone last week.
              J
            Home › Forums › Traction engines › Topics
