Maintenance and setup checking my mill
Home › Forums › General Questions › Maintenance and setup checking my mill
Viewing 25 posts - 1 through 25 (of 33 total)
  • #638324
    petro1head
      @petro1head
      I am on a roll with my workshop so decided to do some maintenance on the mill. (Warco WM18)
      One thing I never checked when I bought it (yes bit late now but better late then never) was if the column was 90deg to the table. So using my new Dial Gauge I clamped a quality engineers square to the table and ran the dial gauge up and down its edge.
      Over 230mm the deflection was 0.33mm which is about 0.0822deg. So the top is leaning in
      Should I rectify or is it within tolerance? If I did rectify I assume just add some shims to the front of the column?
      #29094
      petro1head
        @petro1head
        #638326
        Martin Kyte
          @martinkyte99762
          I would forget the square. If you use your dial gauge on the end of an arm which you can swing in the chuck. Take a measurement East and west along the table in line with the chuck. This will establish column tilt in that axis. Once you have that adjusted correctly you can check the nod or forward and back error by setting the dial gauge to zero when to the right and left of the spindle and then rotating to take a reading in front. If the column is upright all readings should be zero. If not you then should decide if you can live with it or start trying to correct it.
          Regards Martin
          #638328
          petro1head
            @petro1head
            Posted by Martin Kyte on 19/03/2023 17:45:35:
            Regards Martin
            Will give that a go thanks
            #638329
            mgnbuk
              @mgnbuk
              Not OK. Tolerance for a manual machine is usually better than 0.025 / 300mm (thou per foot in old money).
              Did you only check in one plane – you only mention "leaning in" ? My former fitting colleagues called this check "front square" (i.e. Y-Z squareness) – there is also the "side square" check (X-Z squareness).. Both these need to be in spec. if you expect the tool point to stay true to your workpiece datum when the head is raised or lowered.
              The spindle alignment check refered to by Martin is a seperate check carried out after getting the column square to the table in both planes that requires different solutions to rectify should it prove to be in error.
              Pretty pointless IMO messing up your column to table squareness to fix a spindle alignment issue at, say, the head swivel interface. The notion of shimming the column to sort spindle alignment seems to have its roots in the round column mill drills, where it is not that important to have the head raise & lower truly square to the table, as alignment is inevitably lost due to the lack of an alignment key. On a guided column (keyed round colum or dovetailed), column to table squareness is just as (may be more) important than the "tramell" check with the spindle as described above.
              Nigel B.
              #638330
              petro1head
                @petro1head
                Posted by mgnbuk on 19/03/2023 18:07:22:
                Nigel B.
                Sorry a bit confused, are you saying I need to check the Y-Z first?
                #638332
                  I suppose you could have upset the way it came out of the factory when you took the column off to get it onto the stand.
                  If it's not caused a problem in the six years that you have had the mill then it is probably not worth doing anything with it now. If you alter the column then you also risk upsetting the travel of the quill relative to the table as well as tram of spindle axis to table.
                  #638333
                  petro1head
                    @petro1head
                    Posted by JasonB on 19/03/2023 18:20:37:
                    To be honest I have not noticed a problem in those years and its not like I make precision engineering parts.
                    #638335
                    Martin Kyte
                      @martinkyte99762
                      The reason I suggested doing it the way I did is because it eliminates the engineers square which I would not trust to be accurate enough. The Spindle should be true to the column.
                      regards Martin
                      #638344
                      mgnbuk
                        @mgnbuk
                        Check both X-Z and Y-Z. Only doing half the job of checking how your column lies relative to the table otherwise.
                        Alignments are one of those things that, to be done right, have to be done completely and in the correct order – "pick'n'mix" choosing of which bits of the alignment suite you want to check / rectify risks making other areas worse. The Schelsinger & MTB checks for machines are not just a number of checks of particluar alignments, they also specify the order in which the checks are completed. – a former colleague summed it up as "build 'em right from the base upwards".
                        Taken to extremes – if you use an edge finder directly mounted in a collet to set a datum on the corner of a job (head close to the table) then raise the head to get a 13mm jobber drill mounted in a keyless chuck in the spindle (say, raise the head 180mm ) would you want the tip of the drill to still be relevant to your set datum ? Your measured 0.33 / 250mm would mean that it would not be, to the tune of around 0.25mm in one plane alone – you don't know what the error is in the other plane without measuring it. Might just as well have one of the much-derided (in some quarters) un-key round column mill drills if the head alignment isn't maintained along the column traverse.
                        Square accuracy could be confimed by turning the square 180 degrees & re-doing the measurement – result stays the same = square OK, otherwise split the difference ? A square out by 0.33 / 250mm isn't really much of a "square" ?
                        But only after the column is perpendicular to the table which, in turn, is parallel to the base.
                        Nigel B.
                        #638350
                        not done it yet
                          @notdoneityet
                          Posted by Martin Kyte on 19/03/2023 18:51:44:
                          regards Martin
                          Could turn a cylinder on his lathe and use that? Should be square – ad long ad hiix lathe doesn’t face convex.🙂
                          #638358
                          Martin Kyte
                            @martinkyte99762
                            I shall clarify. The spindle should be parallel to the front face of the column as manufactured. It is irrelevant what the relationship of the column to the base is. The spindle axis should be parallel to the Z axis front plane even if the column were lying on a bench.
                            To do a dial gauge turn around test to check nod, the head needs to be either trimmed (set parallel to the side of the column) or a reading taken by dial gauge each side of the spindle on the table and the dial gauge set to half the difference if there is a variation. Rotating the dial gauge to read in front of the spindle will test the nod.
                            regards Martin
                            Edited By Martin Kyte on 19/03/2023 21:35:28
                            #638365
                            petro1head
                              @petro1head
                              Ok, i have made a rig to measure north (back) to south (front) and east (right) to west (left)
                              so far i have check north vs south
                              North:
                              South:
                              As you can see noth is 0.15mm higher than south over a distance of 185mm. This equates to an angle forward 0.0465 deg
                              So now i need to figure out what size shim i will need at the back of the column to tilt it forward.- edit… would the shim needed be half 0.15mm so 0.075mm (3 thou)
                              Once sorted i will then check east vs west
                              Edited By petro1head on 19/03/2023 22:43:19
                              #638368
                              Martin Kyte
                                @martinkyte99762
                                Bearing in mind that very often the misalignment is down to burrs on the mating faces of the base and the column.
                                If you do take your mill apart do a very close inspection of those faces taking special attention to the tapped and through holes where the column is bolted to the base. Also to the edges of the areas. Clean well before reassembly.
                                Why did you use the blocks rather than go direct on the table?
                                tegards Martin
                                Edited By Martin Kyte on 19/03/2023 23:04:59
                                #638373
                                Bill Phinn
                                  @billphinn90025
                                  Yes, not sure why the blocks are there.
                                  Have you tried doing the test [directly on the table preferably] at various points along the table and compared readings?
                                  #638375
                                  petro1head
                                    @petro1head
                                    The head if the mill does not go low enough. Hence the blocks
                                    I will not be dismantling the mill
                                    #638376
                                    Hopper
                                      @hopper
                                      Before you go setting your column square to the top surface of the table, you really should make sure the top surface of the table is parallel to the bed ways and dovetails the table slides on, in both directions.
                                      To do that you would mount your dial indicator's magnetic base on the column, with the plunger of the dial indicator bearing on the table top. You then run the table through its full movement in both X and Y directions. It should return a 0-0 reading in both axes, or near enough, within say .025mm or so.
                                      It is not unheard of for some "low cost hobby mills" to not be machined quite parallel in this area and that can throw your readings out when setting the column square to the base and when tramming the spindle. Or sometimes the table may be riding up on poorly machined dovetails or poorly fitted gib strips, or burrs on the same, etc.
                                      It is a can o' worms once you start doing machine tool alignment.
                                      #638377
                                      petro1head
                                        @petro1head
                                        Posted by Hopper on 20/03/2023 05:58:46:
                                        Tell me about it.
                                        #638379
                                          Should go without saying but the z-axis should have it's lock applied when doing that test and gibs well adjusted otherwise the head can droop
                                          From those readings I would say the column needs to go back not forwards as your dial gauge is being pushed further in on the front reading . If you are not sure measuring the error and not sure how to correct it then as you have not noticed a problem in six years of use is it worth fiddling?
                                          #638382
                                          petro1head
                                            @petro1head
                                            just checked x and y axis and they are spot on.
                                            jason, yeh my error
                                            #638385
                                            Paul M
                                              @paulm98238
                                              I have a WM16 and came to the conclusion that aiming for perfection is not worth the effort. Have you tested the runout along the spindle when locked, as it would be for milling, and unlocked as it would be for a drilling or boring operation. If it's like mine there is at least .002 difference. Apart from tramming the X axis I have left mine well alone and achieve good accuracy for my model engineering tasks.
                                              #638388
                                              Martin Kyte
                                                @martinkyte99762
                                                I think you are sensible in deciding to leave it alone. Tests like this are really very sensitive and can show inaccuracies that are never apparent on your work in the general run of things.
                                                It’s useful to know where the shortfalls are in a machine even if it’s too much bother to correct. Often you can arrange the job to minimise the shortcoming and at least you know what the limits are likely to be.
                                                regards Martin
                                                #638392
                                                Zan
                                                  @zan
                                                  To make trimming easier and more trouble free I got a new car brake disc and use that on the table
                                                  It eliminated the problems associated with the dti plunger dropping into the t slots and questions about has the setting changed. £10 on the bay, well spent
                                                  once you correct the nod  extend the quill and mount the dti on the table and raise/lower the head to check the quill, but correction of any error here is a much bigger problem.
                                                  don’t ask how I know…….
                                                  Edited By Zan on 20/03/2023 09:58:14
                                                  #638397
                                                    Posted by Paul M on 20/03/2023 08:59:04:
                                                    I have a WM16 and came to the conclusion that aiming for perfection is not worth the effort. …
                                                    I'm pretty much in the same camp but, as always, it depends on the type of work being done and the personality of the operator.
                                                    Most of what I do it old-fashioned 'fitting', in which my machines and workshop skills only need to be good enough to get parts to mate. I don't expect measure to better than ±0.02mm (about a thou), and only own a basic micrometer. None of my measuring tools are calibrated. Building to plans, I approximate, and then fit critical junctions together by using the parts themselves as gauges and references. I don't own slip gauges, or anything capable of reliably reaching down to ±0.002mm. I've experimented with 'fitting' using only spring calipers and a steel-rule : works well enough, but requires time and extra care. I'm also a slob, going so far as to accept poor finish and even looking for opportunities not to machine parts at all!
                                                    My exact opposite would be a fusspot, the sort of worker who likes everything 'just so' before starting work, who wants to do the best possible job on everything. Where I'd be happy with an el-cheapo adjustable spanner, he's gpt a set of carefully researched Swiss aero-space spanners in all possible sizes. Perfectionists are much more likely to be upset by warty Far Eastern machines than slobs who just see tools as a means to an end.
                                                    The acid test is rarely applied. Ask 1000 thousand Model Engineers to make a brass rod 9.7mm diameter and 30.1mm long. Half are far eastern, half are western. The rods are sent anonymously to a third party in an envelope identifying the machine used. The third party numbers the parts randomly, mixes them together and sends the boxful on to a team of judges.
                                                    The judges only have the parts to look at. They don't know who made them, or with what. The judges list which parts they think were made by Far Eastern and which by Western. The list is returned to the third party, who compare it with the truth. A chimp choosing randomly will get about 50% right, so only a much better match is significant. The degree to which judges do better than a chimp is a measure of how possible it is to tell the difference between the two types of machine.
                                                    This type of test is designed to thwart human bias, whether conscious and unconscious. It's completely fair. When applied, it often smashes belief systems, such as wine tasting experts really can tell the difference, and old violins are better than new ones.
                                                    If no-one can tell the difference between a rod made on a Myford Connoisseur and a Mini-lathe, then the Mini-lathe ain't so bad!
                                                    Actually there is a difference. Better made machines in good order tend to be smoother in action with more trustworthy positioning. They're easier and quicker to use, which is important when the workshop has to make a profit. Much less important to a hobbyist, who has time to coddle his machines, whether they be down-to-a-price Far Eastern, or clapped out Western antiques!
                                                    I have a WM18 mill that worked straight out of the box. Not perfect but close enough. I only had to tram it after deliberately tilting the head. I can think of several improvements but so far none of them have been worth my while. Other owners might insist on stripping the whole thing down and doing a careful rebuild. They're not wrong in that I'm sure it can be improved, but what arrived on a pallet is acceptable for what I do. It's not better than a Bridgeport and certainly not a tool-room jig-borer!
                                                    petro1head
                                                      @petro1head
                                                      Cheers guys, I have adjusted the angle of the head and is now spot on as well.
                                                      So I may just leave the column
                                                      My problem is I have too much time on my hands
