M6 LH die
M6 LH die
Home › Forums › Beginners questions › M6 LH die
  • #647940
    Peter Simpson 3
      @petersimpson3
      This might sound stupid, I just purchased a M6 LH die to cut some threads. I cannot get the die to cut the thread. Do you have to reverse the direction of the die compared to a standard RH die ?
      #11491
      Peter Simpson 3
        @petersimpson3
        #647942
        Fulmen
          @fulmen
          Yes of course. The die is "screwed on" the stock as if it were a nut.
          #647943
          roy entwistle
            @royentwistle24699
            would you have to reverse a nut to put it on the thread? cheeky
            #647944
            not done it yet
              @notdoneityet
              Er, yes. Depends on whether hand threading or doing it on the lathe. Lathe spindle direction would need to be reversed.
              #647950
              Nigel Graham 2
                @nigelgraham2
                Yes – a thread is cut in the same direction as it works!
                So looking on the end of the screw, a right-hand (conventional) nut will turn clockwise to put it on, a left-hand, anticlockwise. The die runs in the same direction as the nut will.
                NB: if using a left-hand die on a lathe with a screwed-on chuck, there is some risk of the chuck unscrewing as the die bites into the metal. This less with a small thread like M6 but it is still best not to try it under power.
                While here it is worth re-iterating what a post on here some while ago raised:
                If you are threading raw bar-stock, not a diameter you have turned to suit, measure the bar before trying to thread it. Depending on the metal and supplier, it can be sufficiently above nominal diameter, and even out-of-round, to make using a die very problematical.
                Skim the intended length of thread to a few "thou" or about 0.1mm below diameter, or if possible to the standard outside diameter given by the thread-crest rounding. (You will find such details in reference-books or charts.)
                #647953
                Peter Simpson 3
                  @petersimpson3
                  Many thanks, all sorted except I now find the thread is M6 x 0.75 LH Cannot find a supplier of a die that size in the UK. Unless anybody knows differently.
                  #647954
                  Fulmen
                    @fulmen
                    Ouch, that sounds like a real oddball. For an external thread the obvious answer is to single point it.
                    #647956
                    Nick Hughes
                      @nickhughes97026
                      How about this (first on the list in my Google search for "M6 Metric Fine LH Dies" ) :-
                      Edited By Nick Hughes on 09/06/2023 14:35:13
                      #647957
                      Nigel Graham 2
                        @nigelgraham2
                        M6 X 0.75mm is standard ISO Metric Fine.
                        Possibly unusual, and in left-hand form unusual-er still, but I'd try Tracy Tools first, or the Tap & Die company.
                        #647976
                        HOWARDT
                          @howardt
                          Arceurotrade.
                          #647978
                          HOWARDT
                            @howardt
                            Scrub that, forgot lh.
                            #647984
                            David Davies 8
                              @daviddavies8
                              Try Drill Service, Horley but sit down first.
                              HTH
                              peak4
                                @peak4
                                There seems to be a number of Chinese suppliers via eBay, but also one German one if you search for EU, rather than UK
                                Those are made by Baer, which led me to look at their own website HERE
                                https://baer.tools/en/taps-dies/thread-standards/mf-metric-fine-thread/round-dies/for-left-hand-thread/3514/baer-cutting-die-mf-6-x-0-75-left-hss?c=860
                                Bill
