M20 x 1 nut
M20 x 1 nut
Home › Forums › General Questions › M20 x 1 nut
  • #114589
    michael howarth 1
      @michaelhowarth1
      Can anyone out there assist me in locating an M20x1 full nut? I have tried googling to no good result. Thanking you in anticipation.
      Mick
      Edited By JasonB on 17/03/2013 10:07:26
      #22525
      michael howarth 1
        @michaelhowarth1
        #114592
        Brian Wood
          @brianwood45127
          Hello Mick,
          Try local agricultural engineers and structural steel fabricators or suppliers of that sort, I had stuff that size some years ago from farm sales but it went in a clear out.
          #114596
          JC Uknz 1
            @jcuknz1
            Sorry if I am pointing out what you already know but Metric Fine is 20×1.5 rather than 20×1
            #114597
            michael howarth 1
              @michaelhowarth1
              "Sorry if I am pointing out what you already know but Metric Fine is 20×1.5 rather than 20×1"
              Thanks for the interest but M20 x 1 is definitely the size that I require.
              Mick
              Edited to stop adverts obscuring text. J
              Edited By JasonB on 17/03/2013 10:09:44
              #114601
                Full nuts may be hard to find as its an electrical conduit size and they usually just have thin locknuts.
                Tracy's sell the right size tap or screwcut in the lathe
                J
                Edited By JasonB on 17/03/2013 10:11:38
                #114602
                John Stevenson 1
                  @johnstevenson1
                  I thought electrical conduit was 20 x 1.5 Jason ?
                  OP want's 20 x 1 I don't have any but I'll see if I have a tap and if so I can knock you a couple up.
                  have to be later just off out now.
                  #114603
                  Ian S C
                    @iansc
                    Had a look on google, Maryland Metrics Thread Data Charts: Extended thread size range (ISO)
                    20 mm 2.5, 2, 1.5, 1, 0.75, 0.5
                    Ordenary range:
                    20mm 2, 1.5, 1
                    Seems like plenty of choice, didn't realise there was so much, the extended range chart goes from 0.25 mm, to 600 mm. Ian S C
                    #114604
                    speelwerk
                      @speelwerk
                      #114614
                      Jeff Dayman
                        @jeffdayman43397
                        Small Hatz diesel engines used M20 x 1 nuts. Maybe check your local phone listings for a Hatz dealer – they may have a few nuts in stock.
                        JS – electrical conduit is usually M20 x 1 nowadays, not M20 x 1.5.
                        JD
                        #114619
                        John Stevenson 1
                          @johnstevenson1
                          Ok back in and yes I have a tap.
                          Mick, get in touch using message member at the bottom of this post with an address and I'll bung two in the post.
                          #114622
                          michael howarth 1
                            @michaelhowarth1
                            Thanks John. I have left you a message.
                            Mick
