Internal grooving tool?
Home Forums Workshop Tools and Tooling Internal grooving tool?
  • #17378
    Chris Parsons
      @chrisparsons64193
      #150653
      Chris Parsons
        @chrisparsons64193
        Need to cut an internal groove for an O ring in a 5/16 bore?
        I am thinking about making a lathe tool by drilling across a round bar and grinding a square ended insert (with the appropriate relief) from an old drill bit held in by a couple of grub screws – any observations/comments anyone?
        The groove needs to be 0.094" by 0.062" (2.3mm by 1.5mm)
        I have an indexable internal threading tool but it was the square bottom and sides of the groove I was thinking about…
        Chris
        #150657
          Chris,
          That sounds fine … 'though I think a single [axial] screw at the end of the bar would probably do the trick.
          Andy Pugh
            @andypugh44463
            Horn make some nice grooving cutters:
            http://www.ebay.co.uk/itm/251054845232
            And someone is selling cheap holders:
            http://www.ebay.co.uk/itm/251322228837
            For smaller holes thye do this style:
            http://www.ebay.co.uk/itm/251297160167
            #150668
            Ian S C
              @iansc
              I,v got one a little bigger than you need, but it could be scaled. It's just a bit of 3/8" bar(scrap bin), with a chip off a broken industrial power hacksaw blade brazed on the end, I needed it for a one off job, and its been used for a number of jobs since. Ian S C
              #150690
                Easy way is to turn a disc of the required width on the end of a silver steel bar. File out a 90-degree notch to slightly below centreline, harden and temper to straw.
                Mount in a boring tool holder and rotate so cutting edge is on the centreline.
                jonathan heppel
                  @jonathanheppel43280
                  Did some about 10 years ago for 1/4" bore out of a 6mm HSS engraving cutter blank on offhand grinder and angle grinder held in a vice. Material was 316. Neutral rake worked just fine. Job's been working (dymamic, not static) 40 hrs a week ever since. Diameter is the critical dimension with O rings, width is more about type of duty but anyway is less important. Surface finish must be adequate but nothing special. It's easier than first appears.
                  Edited By jonathan heppel on 25/04/2014 22:56:02
                  #150713
                  Andy Pugh
                    @andypugh44463
                    The lathe + silver steel is probably the quickest and cheapest approach. Though if you happen to have a Woodruff cutter lying about then that set up right ought to work too.
                    #150718
                    Oompa Lumpa
                      @oompalumpa34302
                      I have just acquired a lovely 6mm ISCAR Boring bar kit that would do this.
                      You don't want to be buying one for a one off. Lovely bit of kit though.
                      I would go with Neil's suggestion.
                      graham.
                      Edited By Oompa Lumpa on 26/04/2014 06:32:57
                      #150732
                      Steve Withnell
                        @stevewithnell34426
                        Offhand grinder, make any queer shaped tooling you need. Both intentionally and otherwise!
                        The grooving tool I used for eccentric straps was an old letter stamp, ground to shape.
                        Steve
                        #150739
                        NJH
                          @njh
                          Hi Chris
                          I did just as you say.
                          The tool on the right I ground up from an old No.1 centre drill and held it in a holder like the one on the left – which is nothing more complicated than a end of square bar cross drilled for the centre drill and with a hole tapped in the end for a grub screw. Just a few minutes work and it works fine. Mine was for the same job as Steve – eccentric straps. I guess that in a 5/16 bore though you might have some rigidity problems as everything will need to be pretty small so I think Neils method is favourite. ( Well he should know – after all he did get the job!)
                          Norman
