Inlet and Oulet Tube sizes
Home › Forums › Stationary engines › Inlet and Oulet Tube sizes
Viewing 21 posts - 1 through 21 (of 21 total)
  • #140880
    joe best
      @joebest34154
      Greetings
      Is there a standard reference chart showing what size inlet/ out tubes you need for various piston sizes
      or is it as simple as the largest you can get away with and still remain "in scale"
      I believe the general rule is the exhaust should be double the inlet
      Found one for boilers but cant find anything re pipes
      cheers
      Joe
      #3201
      joe best
        @joebest34154
        #140887
          The general rule for port sizing is exhaust should be twice that of the inlet.
          When it comes to pipework there are other factors that come into play such as stroke of piston eg a long 2" stroke x 1" bore will have twice the capacity of a 1" x 1" engine so you can't just go by piston size. Then there is speed, a slow reving beam engine will not need to flow the same volume through the pipes as a high speed enclosed type steam engine.
          There is a table in "Model Engineers Handbook" which lists the suggested pipe sizes for stuart's engines.
          J
          Edited By JasonB on 17/01/2014 08:42:29
          #140911
          Anonymous
            It's simple enough to calculate. If you know the cylinder diameter, stroke, maximum engine rpm and cutoff percentage one can calculate the volumetric flow rate. Assuming that the flow speed is around 4000-6000 ft/min (well below the speed of sound, so no compressibility effects) one can then calculate the pipe area, and thus diameter, needed. If you know the boiler pressure, and degree of any superheat, one can also calculate the mass flow rate.
            If one really wants to get into detail one can also calculate the Reynolds number of the flow to ensure that the flow is turbulent rather than laminar, as that should result in a lower pressure drop.
            In practice, for a small model that isn't likely to be doing any significant work, it probably doesn't matter. The engine will run even if a significant proportion of the boiler pressure is lost on the way to the valve chest. Just use the biggest practical pipe. Of the two the exhaust is probably the more important, as if one can't get the steam out, it's going to be more difficult to get it in on the other side of the piston. Clearly the exhaust passages need to be bigger, as the pressure is lower, assuming some expansion in the cylinder. As stated, times two is a good starting point. The exhaust is particularly important if it is also used to provide a draught for the fire; one needs to ensure that a draught is created in the chimney, without causing backpressure in the cylinder.
            #140977
            julian atkins
              @julianatkins58923
              hi andrew,
              your post was superb and sums up succinctly and thoroughly all the factors in these things. very impressive!
              worthy of careful consideration by anyone building a steam loco or any steam engine.
              cheers,
              julian
              #140979
              joe best
                @joebest34154
                thanks for the replies
                A copy of Model Engineers on its way
                cheers
                Joe
                #141039
                MICHAEL WILLIAMS
                  @michaelwilliams41215
                  Just a few notes :
                  Steam flow in small engines is controlled for the most part by constrictions in the flow line and by the rate at which engine is capable of accepting steam .
                  There are obvious constrictions at regulator and steam ports and less obvious ones at changes of diameter in pipework and in sharp bends .
                  Flow through constrictions is estimated using a trial and error process and reference to steam tables to do it properly but an order of magnitude estimate can be obtained using Bernoulli and average steam properties .
                  A plain pipe can be a constriction under some circumstances but generally if a feed pipe has larger flow area than any of the engine and regulator constrictions it will be completely adequate by default and no calculation will be nescessary .
                  When there is a chain of constrictions in any flow line all of them can have their effects but it often happens that one of them is dominant and the others relatively minor in effect .
                  Where there is a dominant constriction it is important to make sure that it is the right one otherwise huge losses will occur .
                  Two examples :
                  (1) Whistle .
                  Simple set up with a valve and whistle . All pressure drop has to occur at whistle to make it work properly . If whistle valve is too small most of pressure drop occurs in valve and very little at whistle .
                  (2) Steam turbine .
                  Valve and jet . Same as whistle exactly – jet has to be dominant constriction . If valve inadequate then losses up to 90% can occur .
                  This incidentally is one of the reasons why most model turbines produce no power .
                  Small engines have short steam and exhaust pipes and in these short pipes flow is almost never fully developed as either laminar or turbulent – there is not enough distance for flow to settle down . Also in short pipes the laminar flow / turbulent flow consideration hardly makes any difference to flow and losses .
                  When sizing a pipe on its own just for a required flow it is designed as a nozzle first and then – if its a long pipe – the flow pattern , heat losses and friction loss are considered .
                  Whittle developed the theory of flow in constrictions in series . Constrictions in aerodynamics are usually always called nozzles .
                  Porta developed the theory of steam flow in constrictions in series as applied to steam and actually applied the results to real engines with startling improvements in efficiency . Unfortunately it was too late in the day as steam was being phased out everywhere so the project faded away .
                  As regards the OP’s question – you would be hard pressed to get it wrong in a model size engine . All the steam needed will flow through very small pipes anyway .
                  Regards ,
                  MikeW
                  #141142
                  Anonymous
                    Posted by MICHAEL WILLIAMS on 18/01/2014 17:20:22:
                    That's very interesting; I am currently looking at the maths of compounding, and then intend to move onto steam flows to ensure that the passage ways in my traction engine are not overly constrictive. The basic steam passages are about 15mm diameter, at around 10 bar. With those numbers, assuming saturated steam, I expect a Reynolds number on the order of 140000. That should put the flow comfortably into the turbulent regime. I'd be interested to understand better what happens with relatively short pipes. Does the flow start out laminar and stay laminar, or degenerate into a turbulent flow if the Reynolds number is large enough? If so what would you estimate the pipe length to be to ensure a transition to turbulent flow?
                    #141177
                    MICHAEL WILLIAMS
                      Hi Andrew ,
                      I’ve only just seen your posting .
                      I’ll send you a proper reply when I have more time later .
                      MikeW
                      #141344
                      MICHAEL WILLIAMS
                        The following applies to reasonably well behaved fluids and subsonic flow .
                        (1) Flow in short ducts is determined almost entirely by nozzle characteristics of duct and only a little by frictional effects and laminar/turbulent conditions .
                        (2) Turbulent v laminar flow settling down distance for a long straight uniform pipe is typically from 20 diameters to 100 diameters . Very uncertain in reality and for general purpose estimates it is often taken arbitrarily as 60 diameters . So for 15 mm pipe about 900 mm – ie in a normal steam cylinder passage or the like it never settles down at all .
                        (3) When duct is anything other than a long straight uniform pipe there are no rules at all – much more detail calculation or practical tests are needed .
                        (4) Where the transition from previous flow conditions into duct is reasonably smooth then generally what goes in is what comes out – turbulent in turbulent out / laminar in laminar out .
                        (5) Where transition from previous flow conditions into duct is not reasonably smooth then flow can be tripped from laminar to turbulent by local disturbances . Examples are abrupt change of flow area , sharp edges , sharp changes of direction and projections .
                        The reverse of turbulent tripped into laminar flow very rarely occurs naturally thogh it can be contrived by , for example , passing flow through a nest of short fine tubes .
                        Where transitional control of flow matters critically then smooth slow area transitions , slow bends and possibly internal guide vanes are needed .
                        There is a particular problem with steam in ducts in that it may change state at transitions – ie becoming more/less wet/superheated .
                        This effect can trip flow from laminar to turbulent in higher speed flows .
                        (6) A useful tool for quick estimates of how well behaved flow will be at transitions is to draw out by eye the streamline pattern . I’ll describe this further if wanted .
                        The flow can actually be fully modelled on computer but there are many pitfalls and the sketch is always a good start anyway .
                        (7) Reynolds number is a measure of the ratio of inertia to viscous forces in a particular flow .
                        That’s what it says in books anyway . Really it is the ratio between forces tending to destabilise the flow – and forces tending to stabilise the flow .
                        Thus a thick slow moving fluid flow is likely to be stable (ie laminar) whereas a thin fast moving fluid flow is likely to be unstable (ie turbulent) .
                        Reynolds number is useful for estimates but not for detail calculations . Really the whole theory was developed for sewers and drains and becomes less reliable when used on more sophisticated flows .
                        MikeW
                        Edited By MICHAEL WILLIAMS on 22/01/2014 10:58:15
                        Edited By MICHAEL WILLIAMS on 22/01/2014 11:20:41
                        #141347
                        MICHAEL WILLIAMS
                          (8) Flow of steam from a normal locomotive boiler through regulator and into cylinder passages is likely to be turbulent regardless – the steam is disturbed anyway as it leaves the boiler and so many changes of area , bends and sharp edges in the steam line almost make certain of it .
                          Possible exception when multiple parallel fine tube superheaters are fitted – these tend to smooth the flow somewhat .
                          (9) Worth mentioning the difference between disturbed flow and turbulent flow . Disturbed flow is usually a localised effect – like the eddies which form downstream of a weir .
                          Turbulent flow is a bulk effect affecting large distances in the flow .
                          Disturbed flow will often trip laminar flow into turbulent .
                          (10) A more critical effect than just laminar/turbulent flow is boundary layer formation and it’s management in real applications . More on that if anyone interested .
                          MikeW
                          Edited By MICHAEL WILLIAMS on 22/01/2014 11:22:37
                          #141418
                          julian atkins
                            @julianatkins58923
                            hi michael,
                            could you possibly summarise the above so that those of us without a detailed engineering background can understand, and put it in simple language for miniature loco builders please? what does the above mean for miniature locos? the late jim ewins was of the view that so long as our locos were superheated the steam was (until expansion) much more fluid than fullsize and that flow problems encountered in fullsize werent such a problem.
                            cheers,
                            julian
                            #141436
                            MICHAEL WILLIAMS
                              Hi Julian ,
                              I’ll see what I can do .
                              Regards ,
                              MikeW
                              #141498
                              Sub Mandrel
                                @submandrel
                                I'm reminded of 'turbulators' – lengths of cotton glued along the wings of model gliders.
                                julian atkins
                                  @julianatkins58923
                                  that's the sort of terminology that started me scratching my hair out!
                                  #141522
                                  Anonymous
                                    Posted by Stub Mandrel on 23/01/2014 19:12:50:
                                    Standard on full size sailplanes too, except we don't use cotton. The turbulator is normally a zigzag plastic strip running along the wing at about 2/3 to 3/4 chord. The plastic is hard, and surprisingly sharp, it'll shred your fingers if you're not careful. And oddly enough pilots get sulky if you get blood all over their nice polished wing. crook
                                    #141588
                                    Sub Mandrel
                                      @submandrel
                                      Sounds like a good way to appease the spirits of the air for trespassing on their clouds!
                                      Anonymous
                                        Some interesting points raised by MikeW. The steam flow from boiler to HP valve chest in my traction engine is fairly convoluted, with several changes of section and bends. The steam is saturated, and most likely wet, which complicates the calculations. I doubt that the flow will be laminar. I am going to base my port size calculations on a flow speed of about 5000 ft/min, so well subsonic, but still a high enough Reynolds number to ensure, in theory, turbulent flow. When I finish the engines it will be interesting to measure the pressure drop from boiler to HP valve chest under varying conditions. When the regulator is partially closed there is a sharp edged transition into the safety valve chest. I am assuming that this will approximate an isenthalpic expansion, with the benefit that it will dry the steam.
                                        I've found Reynolds numbers to be fairly useful in aerodynamics, at least for ensuring that experimental results are comparing like for like, at least for subsonic flows. Supersonic is a whole different ball game. Boundary layer control is of particular interest for sailplanes. Most of the modern wing sections control laminar flow boundary layers by controlling pressure gradients. Although in the past holes for blowing/sucking air have been tried to ensure that the boundary layer stays attached.
                                        #141799
                                        MICHAEL WILLIAMS
                                          Ducts internal to high performance engines have the opposite problem to sailplane wings – it is sometimes nescessary to use boundary layer strippers to get maximum flow through .
                                          Very wet steam can form ‘super’ boundary layers – thick stable films on inside of pipe walls . Probably not a problem in a traction engine but it can be in some situations .
                                          Always though worth considering fitting a droplet catcher when steam take off is too near to top surface of water in boiler .
                                          Actual lumps of water send all calcs out of the window and can cause real damage .
                                          MikeW
                                          #141936
                                          Anonymous
                                            A very interesting discussion, but I suspect way beyond what we actually need in order to make some sensible calculations looking at port sizes and the steam flow from the boiler to HP valve chest and beyond to check that the passages are of a sensible size.
                                            #142116
                                            Mr Moo
                                              @mrmoo
                                              The level and depth of knowledge and experience available via forums such as this one never ceases to amaze and instruct me. Thank you for the lessons!
                                            Home › Forums › Stationary engines › Topics
