How to tell EN1A
How to tell EN1A
Home › Forums › General Questions › How to tell EN1A
  • #190423
    Chris Denton
      @chrisdenton53037
      Morning, I've had some steel delivered. It is meant to be EN1A.
      it is a lot harder to cut, the chips are different and the cut surface finish isn't as good.
      The bar has a very smooth finish with a fine spiral pattern and is very bright, like stainless. There is no pitting like there is with my usual EN1A. I
      Its very similar to EN8 to machine.
      #23897
      Chris Denton
        @chrisdenton53037
        #190425
        mechman48
          @mechman48
          Have you checked your delivery note / receipt.. is there any colour ID on the end of any of the pieces… ?
          George.
          #190427
          Chris Denton
            @chrisdenton53037
            Yes, delivery note said EN1A and the colour on the end was the correct colour they use for EN1A.
            #190429
            Ady1
              @ady1
              Get a bar from another source, with a receipt, and compare them on your lathe
              Sounds like it's going to be a pain to get it sorted out
              #190431
              Chris Denton
                @chrisdenton53037
                I have loads of EN1A here from the same supplier, completely different. I'm having to lower the speed and reduce the cut depth on this stuff!
                #190433
                Ady1
                  @ady1
                  I'd take it back, with a sample from the previous delivery. Sounds like they've cocked up the grade designation when it arrived at their warehouse
                  edit: If EN8 is 100quid a ton and EN1 is 20 quid a ton it might be worth hanging onto it…
                  I Checked, no real difference
                  Edited By Ady1 on 18/05/2015 11:07:21
                  #190434
                  John Stevenson 1
                    @johnstevenson1
                    EN8 machines quite nice, this sounds more like EN3 or 3B which can be a bit stringy to cut.
                    The spiral marks are no test, all depends on which set of dies they pull the material thru.
                    #190436
                      Check you aren't comparing EN1aPb with EN1a.
                      Chris Denton
                        @chrisdenton53037
                        Posted by Neil Wyatt on 18/05/2015 11:44:25:
                        Is there that much difference?
                        #190446
                          I would say "it is a lot harder to cut, the chips are different and the cut surface finish isn't quite as good."
                          Steel cuts like butter
                          Tubal Cain puts 'freecutting mild steel' (EN1aPb) in the same machinability class as brass, and a different one from ordinary mild steel.
                          Edited By Neil Wyatt on 18/05/2015 12:36:12
                          #191566
                          Chris Denton
                            @chrisdenton53037
                            Thanks.
                            The supplier took it back and replaced it.
                            All is good again.
                            #191571
                            Nigel McBurney 1
                              @nigelmcburney1
                              I have bought my steel from two large suppliers over the last twenty years,all in 10 ft lengths, and I have noticed variations in machinability ,particularly the steel with the slight spiral marks,which I assume is from a rolling process,plus the occasional laminations which can be heard clicking during turning,on one occasion a lump fell out from a 40 mm bar,plus correctly marked material supplied but not what I ordered,and this from companies with all the quality approvals!!!
