Honing vs reaming
Honing vs reaming
Home › Forums › Workshop Techniques › Honing vs reaming
  • #126565
    ken king, King Design
      @kenkingkingdesign
      Does anyone out there have experience of honing small bores ? Can you recommend suppliers of various grade stones, from rapid metal removal to polishing? So far I've come across Sunnen, a Swiss company who trade worldwide. I'm calling their U.K. office on Monday next, but would like to know of others, and discuss the relative merits/problems/costs of the technique. Can you contribute ?
      #15650
        @kenkingkingdesign
        a viable alternative technique ?
        #126567
        Bill Pudney
          @billpudney37759
          Ramon "Tug" Wilson did a really good thread on lapping small, under 20mm diameter bore on another site, its probably non PC to mention it here, but it deals with model engine making. It basically demonstrated how to produce a suitable adjustable lap, how to use it, and the grit to use. Very, very interesting.
          cheers
          Bill
          Edited By Bill Pudney on 10/08/2013 02:50:31
          Edited By Bill Pudney on 10/08/2013 02:51:06
          #126570
            I think Ramons Lapping article is due for publication in ME, it does touch on honing but lapping may be more appropriate for a small bore such as an aero engine.
            J
            #126593
            Ian S C
              @iansc
              JasonB, I agree that lapping would in my oppinion be the way to go. Ian S C
              #126605
              Sub Mandrel
                @submandrel
                What's the bore for? If reaming is adequate for teh job, why replace a simple, rapid operation with a fiddly, slow one?
                  @kenkingkingdesign
                  Well Stub, my interest stems from recent unhappy experiences with reaming 1" bores. I'm awaiting more info but I think there are some preconceived notions of what can or can't be achieved with honing, and that it may prove to be a suprisingly versatile technique, capable of either rapid metal removal or very fine finishing. As I learn more I'll post it here for all to absorb. Here's another question to test understanding:- What's the difference between honing and lapping, or is each an extension of the other (do they in fact overlap – ouch, sorry),
                  Regards to all,
                  Ken.
                  #126641
                    Again a lot bepends on what you are trying to do with the hone, yes it will give a good finish subject to the grit of the stones but if you are using the common brake cylinder hones then they won't true the bore like lapping will.
                    Also a hone does not match a piston to a liner, once you get down to lapping the piston into the bore at 1000g you get a better fit than trying to use internal and external hones to acheive the same fit. So a honed surface may be OK for a piston that will have rings but if you are running a ringless piston in a compression diesel or glow engine then it sbetter to lap one to the other.
                    There is a bit of lapping in my Firefly thread, though Ramon goes into far better detail.
                    #126642
                      Posted by ken king on 10/08/2013 18:58:27:
                      Regards to all,
                      Ken.
                      If I recall correctly:
                      Honing involves the use of hard abrasive stones, typically more than one, mounted on a mandrel … and finishes to a preset size.
                      Lapping involves a relatively soft "plug" loaded with abrasive paste … and the finished size is therefore perhaps less predictable.
                      Just to confuse matters: one of the classic Honing machines is made by Delapena.
                      Russell Eberhardt
                        @russelleberhardt48058
                        I don't know what size cylinder you're talking about but I've found one of these works well.
                        Russell.
                        #126645
                        Clive Hartland
                          @clivehartland94829
                          Reaming as against honing/lapping, the reamer brings a hole to a set size and depending on the quality of the reamer and the amount of metal removed gives a parallel hole with a good finish suitable for most engineering purposes.
                          Honing/lapping is used to bring a bore to a size so that a pre-made item (Piston) will fit with the correct clearance. Lapping is used to produce a very fine surface for rotary or longitudinal motion, again as in a model diesel motor.
                          Automotive honing has an automatic system (Sunrod) where the bore size is dialled in and away it goes until that size is reached. The spiralling motion of about 45 deg. suits the bedding in of the rings on the piston. In fact the bore when viewed is quite visibly marked. The bore, if badly worn can be bored to a set size and then is honed to tolerance. In all, 4 cyl. can take about 40 mins. with a bore size of 3" to 4".
                          For most modelling applications anything up to half inch is OK to ream, above that as the clearances increase then lapping can be used. Not always, as it can be difficult to hone or lap a large dia. hole of limited width so other methods are better.
                          making small spindles in a steel mount I allowed 1/100 mm for 10/15mm dia. This being a hand turned operating knob where any slackness would show up in the optical measuring system.
                          #126658
                          JohnF
                            @johnf59703
                            Hi Ken K, I have used both Delapena and Sunnen hones, mostly Delapena who are in Gloucestershire I think. Personally I have found little to choose between them and most of the tooling is interchangeable.
                            You can get permanent or disposable mandrels, small sizes are always disposable because there is no possibility to fit wear shoes.
                            If you PM me with your email I can send you a PDF of both companies brochures.
                            Stock removal is relatively slow compared to other methods of machining but it depends on size, material and length of the hole as to haw fast you can remove metal.
                            I feel sure the machines Gray is talking about are modern and more sophisticated than my old Sunnen honing machine which is about 60 years old I think but the principal is the same except there is nothing to preset or control the finished size other than experience.
                            Hope this helps John.
                            #126669
                            Hopper
                              @hopper
                              What was the problem you encountered with reaming? In what application?
                              Reaming is going to be a much more rapid metal removal method than honing. Honing is essentially a finishing technique.
                              Couple of things that make reaming go better include drill the hole undersize first, then bore the hole to within 5-10 thou of finish size. Boring gives a straight, concentric hole for the reamer to then follow. Machine reamer, or at least a fixed hand reamer, will more easily give a good result than an adjustable hand reamer. If I have to use an adjustable hand reamer, I will bore to within a couple of thou, then ream, then take the last half to one thou out with a brake cylinder hone. If you are reaming brass, a worn old reamer actually works best. A new sharp reamer will dig in. Running a small oilstone over the cutting edges of a new reamer will dull them enough to work well on brass/bronze.
                              #126687
                              Sub Mandrel
                                @submandrel
                                I would ream bearing holes, but hone or lap the bore of an internal combustion engine.
                                What application are you looking at now?
                                  @kenkingkingdesign
                                  To complete the picture, my particular problem arose when trying to ream 1inch diameter steam engine cylinders. I have bored them to within a couple of thou, with a very nice, uniform finish. I was using a brand new hand reamer, not an adjustable, and the first bore reamed ok., though not as good as I'd hoped The second was a disaster, with the reamer digging in and jumping from one tooth to the next, six jumps per rev, equal to number of flutes. I never thought of dulling the tool edges; that's kind of counter-intuitive isn't it ? Maybe that would be the answer, but why didn't the effect arise with the first cylinder ? I'm reluctant to put the reamer anywhere near the third and final bore, I think understandably, and that's why I started thinking about other means of improving the surface finish from fine boring to polished.
                                  #126711
                                  Sub Mandrel
                                    @submandrel
                                    For steam cylinders, I would either accept a really good bored finish, or hone lightly with very fine grade wet and dry or used emery paper oiled and wrapped around a stick.
                                    A polished finish can be counter-productive inm a steamer as it doesn't hold oil.
                                      Posted by ken king on 11/08/2013 12:00:47:
                                      Ken,
                                      Attempting to answer these points
                                      • It's often better to ream more than a couple of thou
                                      • Dulling the edge will effectively give negative rake [compare the clockmaker's five-sided cutting broach]
                                      • I'm guessing that the first cylinder was better; either because the machined bore was slightly smaller than the second, or because you were pushing harder.
                                        Whats the material you are cutting and what are you using as packing or rings, Iron rings in an iron bore will be better suited to a honed finish. O rings in a gunmetal casting will want lapping if they are to last.
                                        J
                                        #126720
                                        Norman Lorton
                                          @normanlorton75928
                                          I think I know where Ken is coming from as I had the same questions a couple of years ago. The question breaks down into getting a) an accurate bore of correct diameter, and b) a suitable surface finish. I would add a new variable in that striving for either the bore or finish can give an incorrect bore profile, especially a 'barrel' with a larger bore in the centre or a 'flare' with larger diameters at the outsides. I think this is the hardest error to correct for.
                                          A reamer gives a good parallel bore of true diameter, up to perhaps 1" in non-professional hands, but the finish might be messy, as Ken says. I find that a flap of emery or wet and dry paper, held in a small wooden split stick, can produce excellent finishes, working from 200-1000 grit with plenty of paraffin or WD40 to wash away material. The job rotates in the lathe at a few hundred RPM and the stick is carefully moved in and out to avoid any creation of the barrel effect. Problem is it also enlarges the bore by 0.0005" or more.
                                          Honing (using stones held on a frame) is obviously a superb technique in the professional machines described above as the bore is enlarged from its rough cut by a few thou and the finish of cross honing is perfect for cast iron rings in a cast iron bore, and parallelism is maintained. But, it is most suitable for bores of 2" diameter and upwards. I have seen sets of small hones at the ME Shows and wander what success people have had with them?
                                          I did some web research and lapping (grinding paste on soft mandrels) is the described technique for getting accurate bores of suitable finish. I wanted to make some bronze bushes in which would run stainless pushers of diameter 0.8749 – 0.8750. The bushes were 1" long and the differential thermal coefficients of expansion (appx. 0.001" between stainless and bronze over 100 degC) meant careful measuring at a fixed temperature. I bored the bushes to 0.8735 – 0.8740 and then lapped them in the lathe using a home made mandrel with an aluminium body of nominal 0.8730 diameter and an end taper wedge to progressively enlarge it from the centre. The mandrel was designed to enlarge as a slight barrel, so as to counter the effect of it producing a 'flared' bore diameter increase in use. Diamond pastes, plus light oil, starting at 40 micron (400 grit) would remove a thou in 60 seconds. 14 and 5 micron then produced near polished surfaces. Absolutely thorough washing before measuring or changing pastes was essential.
                                          Lapping this way produced bores that were so close in diameter to the stainless pushers that they were locked solid at 15 degC, just moved at 25 degC, and slid like glass at 35 degC. If it is an iron piston in an iron barrel one will not see this temperature effect.
                                          I have no professional training but taught myself, so make a mandrel lap Ken and have a try! PM me for more if you wish as I have said far too much in this reply and will have bored too many.
                                          #126727
                                          Norman Lorton
                                            @normanlorton75928
                                            Search also for "Honing bronze cylinder bores" in the search keyword box above as this topic was covered in January 2012.
                                            #126796
                                            Ian S C
                                              @iansc
                                              on some of my hot air engines I have used a lap made of wood, and charged with grinding paste. The woden cylinder is split length wise, and a wood screw, or wooden wedgeis put in the open end of the split. The lap is held in the chuck of the lathe, and run at a moderately low speed, while the cylinder being lapped is moved back and forth by hand. This is one of the only places I wear a glove, there is a bit of torque, but the work gets quite warm, it's a job that takes time. Ian S C
                                              #128513
                                                @kenkingkingdesign
                                                Here's an update on my problem. I had to rebore the castings slightly oversze to get rid of the worst reamer effects, encountering some work-hardened areas in doing so. I obtained some 1/8" thick copper sheet and made up an expandable hone to the design given by Ramon in his thread. I had bought on spec some Silverline Polishing Compound, on eBay, and when mixed with 3-in-1 oil it looked useful, so away we went, albeit with a little trepidation, after all, these were a client's castings !
                                                In the event I found the whole process remarkably simple and controllable. I was able to bring all three bores to the same diameter (there had been just over a thou. difference between them after reboring) and true circularity and parallelism. Bores were checked using an internal micrometer, which in turn was checked with an external micrometer, reproducing the 'feel' of the bore. Thanks Ramon, and all who pointed me in his direction.
                                                The next requirement was to improve the surface finish a little, and here a small brainwave struck. I pass it on in the hope it may prove useful to you. I found some old but unused self-adhesive draught excluder, 1/4" wide grey nylon fur on a nylon backing strip, and having measured the compression available I turne down a length of broom handle to a suitable diameter. I drilled a transverse hole near the end, and another near the lathe chuck. I folded the excluder backing to get it into the first hole, pulled it through and trimmed off, then spirally wound the excluder round the wooden mandrel, finishing similarly at the second hole. The holes were tight enough to hold it in place. Taking my trusty green buffing compound block I mixed scrapingsinto a runny paste with oil which was then dosed onto the fur. A casting was threaded on and subjected to a few cautious passes up and down the length of the mandrel. Inspection gave me the confidence to proceed at a slightly higher speed, and in a short time all three bores were showing a polished finish with a fine underlying scratch pattern from the honing, which I think may well be close to the ideal mentioned by some contributors to Ramon's thread, and mine too.
                                                Let me know if this idea is useful,
                                                Regards to all contributors,
                                                Ken.
                                              Home › Forums › Workshop Techniques › Topics
