help – cleaning for soldering
Home › Forums › Beginners questions › help – cleaning for soldering
  • #97603
    nigel jones 5
      @nigeljones5
      got a problem – expanded copper tubes into firebox but they leak – not suprised as the reaming was horrid! I want to caulk them in but the steel is no where near clean enough to take comsol. I cant get in with even a small wire brush so is there a chemical solution (no pun intended!!)
      #6322
      nigel jones 5
        @nigeljones5
        #97614
        WALLACE
          @wallace
          Can you not ‘get in there’ with a sandblaster ? It works well on stainless steel I’ve had to silver solder in the past.
          W.
          #97616
          CuP Alloys
            @cupalloys
            Suggest you don't use sand blasting, sandpaper, emery cloth or similar. They are prone to leaving grit or glue residue behind which fluxes will not remove. Result – pinholes in the joint so the "repair" still leaks!
            Most weak acids will remove scale eg citric, acetic (vinegar) or proprietary kettle cleaners.
            keith
            #97622
            modeng2000
              @modeng2000
              Hi Keith,
              Is the cupalloys website down today?
              CuP Alloys
                @cupalloys
                Hi John,
                I think it is routine maintenace on the server. Experience tells me it will be running normally shortly.
                My apologies for the inconvenience.
                keith
                #97630
                modeng2000
                  @modeng2000
                  Thanks Keith, doesn't it always happen when something needs to be referred to!
