Hello from South Yorks
  • #368505
    Bitzer
      @bitzer
      Hi all,
      Long time engineeriring doodler here, mainly 16mm/ft scale railways and smaller live steam things :
      Always experimenting with new ideas so I'm making my first excursions into 3d printing. However, I'm currently nursing a very sick NC milling machine, so I am hoping for some assistance.
      That probably means I wil be taking more than I can give, for the moment, so please be patient with me
      Bitzer
      #40374
      Bitzer
        @bitzer
        #368516
          Welcome to the Forum Blitzer.
          Brian H
            @brianh50089
            Welcome Bitzer, I'm probably not far from you at Mansfield!
            You'll find lots of help on here if you have any questions.
            #368530
            Phil P
              @philp
              Hi Bitzer
              Just curious if your little Burrell is based on any particular full size engine.
              Phil
              #368535
              Bitzer
                @bitzer
                Thanks for the welcome, guys.
                Hi Phil,
                It's based on a 10NHp Burrell road loco, but not any one in particular. I took the main dimensions from various GA drawings in the book "St. Nicholas Works" and then used photos for the details, so there are some details from "Ex-Mayor" and bits of "Clyde" in there. Ex-Mayor used to work around South Yorkshire (well before my time!) so a future project will be a showman's version.
                The wheels look rather too heavy as they are temporary plastic ones from a Lledo model, so I have to be careful not to turn the burner up too far! When I get my milling m/c up and running again one of the jobs I have to do is fret out some brass spokes so I can fabricate new ones.
                Bitzer
                Edited By Bitzer on 22/08/2018 21:20:51
                #368539
                peak4
                  @peak4
                  Hello from Sheffield, though I'm in the process of flitting to Buxton.
                  Bill
                  #368592
                  Bitzer
                    @bitzer
                    Posted by peak4 on 22/08/2018 21:37:15:
                    Bill
                    Hi Bill,
                    I hope it wasn't something I said
                    Bitzer
                    #368593
                      Posted by Bitzer on 22/08/2018 19:36:36:
                      … and smaller live steam things :
                      If that's a live steam engine … some detail shots would be good to see.
                      maybe when you are fitting the metal wheels
                      [very impressed]
                      #368671
                      Bitzer
                        @bitzer
                        Hi Michael,
                        Yes it is, but it's nothing special, apart from being small (4mm/ft).
                        A simple pot boiler with an oscillating cylinder, 3mm bore x 4mm stroke. The cylinder is hidden behind the side screens and the visible cylinder block is only an empty shell.
                        Firing is by butane gas using a trough burner in the firebox and belly tanks. Run on one filling is about 2 minutes.
                        It was intended to run with the "Faller" magnetic road system (the guide skate is just to the right of the pound coin) but really it runs too fast to be authentic. I am trying to draw up a Sentinel lorry using the same type of engine, which should look better running at speed.
                        My mk 1 eyeballs are not really up to marking out such small stuff, which is why I need my CNC mill running again!
                        Bitzer
                        Edited By Bitzer on 23/08/2018 13:53:28
