Glow Plug Thread
Glow Plug Thread
Home Forums Beginners questions Glow Plug Thread
  • #107998
    Sub Mandrel
      @submandrel
      Can anyone confirm what the thread is on a standard glowplug? I measure a slightly oversize 6mm x 0.6 pitch or a slightly undersize 1/4" x 40tpi, but the thread is so short I can't be confident.
      Before anyobne says google -there seems to be just as much confusion out there as here!
      Thanks
      Neil.
      Edited By Stub Mandrel on 05/01/2013 20:10:46
      #6502
      Sub Mandrel
        @submandrel
        #108002
        Les Jones 1
          @lesjones1
          Hi Neil,
          The results from googling "model glow plug thread" seem to indicate the normal thread is 1/4" x 32 tpi This does not match your measured value of 0.6mm / 40 tpi.It looks like the plug you have is not standard.
          Les.
          Edited By Les Jones 1 on 05/01/2013 20:30:50
          #108003
            Its a UNEF 1/4×32 so 60degrees unlike out ME 1/4×32 which is 55deg
            I got my taps from here when I built the Firefly, fitted perfectly on a standard OS plug
            Edited By JasonB on 05/01/2013 20:37:25
            #108004
            I.M. OUTAHERE
              @i-m-outahere
              According to wikapedia it is 1/4×32 UNEF .
              #108005
                Neil,
                This seems to confirm Les' findings
                Jason beat me to it.
                Edited By Michael Gilligan on 05/01/2013 20:40:00
                #108009
                Sub Mandrel
                  @submandrel
                  Thanks for the rapid responses. I found wikipedia, but there seemed to be some disagreement. I eyeballed the pitch at 0.024" using a caliper (which is why I though 40tpi), but I reckon it is probably a standard one.
                  Not sure I've got 1/4" by 32 ME anyway, but I have a suitable threading tool – a homemade tap should be fine in the aluminium head.
                  Thanks again,
                  neil
                  #108031
                  Ady1
                    @ady1
                    From the ELFs book they can be 32, 40 and sometimes even 48 TPI
