Glasses — sometimes called headlamps
Home › Forums › The Tea Room › Glasses — sometimes called headlamps
Viewing 25 posts - 1 through 25 (of 26 total)
  • #587508
    Former Member
      @formermember12892
      #36769
      Former Member
        @formermember12892
        #587512
        Grindstone Cowboy
          @grindstonecowboy
          Presumably so they don't have to produce RH and LH versions of the hinge? Is the other side with head uppermost?
          Rob
          #587515
          Former Member
            @formermember12892
            #587516
            DiogenesII
              @diogenesii
              Stick a dab of superglue / 638 on them
              #587534
              Speedy Builder5
                @speedybuilder5
                When I take my glasses off, I can't even see the screws !
                #587536
                BASS 666
                  @bass666
                  Posted by DiogenesII on 27/02/2022 18:10:31:
                  that's what i do with mine ..
                  #587588
                  Henry Brown
                    @henrybrown95529
                    I use clear nail varnish over the screw head, I can scrape it off and have new lenses fitted in the old frame…
                    #587595
                    David Caunt
                      @davidcaunt67674
                      Posted by Henry Brown on 28/02/2022 12:33:06:
                      Your lucky our optician says sorry can't use the old frame. It used to be OK up until the last 3 pairs. As one of the frames was sold as indestructible it really p??ed me off.
                      #587597
                      duncan webster 1
                        @duncanwebster1
                        Find another optician, the prescription is yours, you can ask for a copy
                        Edited By duncan webster on 28/02/2022 14:16:33
                        #587603
                        Henry Brown
                          @henrybrown95529
                          Exactly what Duncan said, go elsewhere if they won't do as you ask. We use a place in Worcester called The Vision Factory where they grind the lenses and fit them to the frames, a fraction of the High Street cost too…
                          #587604
                          Juddy
                            @juddy
                            I would imagine the screws are underneath so that if they do come out they fall away from the eye not into it?
                            #587607
                            Former Member
                              @formermember12892
                              #587608
                              Former Member
                                @formermember12892
                                #587612
                                KWIL
                                  @kwil
                                  As Henry Brown says find a vision supply shop (not an optician). Have done this for the last 40+ years. No charge for reglasing just the lens cost.
                                  Only downside, if your prescription is "wrong" (it happens) that is your added cost, has only happened once in all that time so still cheaper overall. More likely to be more realistic in frame costs when you want to change.
                                  #587632
                                  DMB
                                    @dmb
                                    I believe that the High Street opticians offering NHS eye tests have to give you your prescription by law. Specsavers put pressure on me to buy their overpriced frames which I now buy online at a sensible price. Good quality and screw heads always on top. Boots at least, will replace screws or bend side arms if too loose. At least they used to, don't know if they still do. I also got fed up with the conveyor belt feeling at Specsavers so now use Vision Express – get treated more like a human being.
                                    Above is my opinion and experience, so if Specsavers don't like it, they need to up their game.
                                    #587661
                                    Anthony Knights
                                      @anthonyknights16741
                                      Specsavers wanted to charge me MORE to re-use my old frames. Told them what to do and took my prescription else where. Now I have had cateracts in both eyes operated on, I don't need opticians any more and get away with a set of cheap, off the shelf, reading glasses for close up work.
                                      #587671
                                      Anonymous
                                        Specsavers are a franchise operation, depends on which franchisee runs it as to how you are treated. Can't fault our local one for no hassling pleasant customer service and aftersales service. Had screws and nose pads replaced with no problem or charge.
                                        #587677
                                        Alan Jackson
                                          @alanjackson47790
                                          Cillary Blue are a good company who make new lenses to your prescription and fit them to your old frame.
                                          Alan
                                          Edited By Alan Jackson on 01/03/2022 10:49:21
                                          #587679
                                          ega
                                            @ega
                                            Posted by Alan Jackson on 01/03/2022 10:48:49:
                                            Alan
                                            Thanks for this tip. The big players who won't reglaze should think on. The rot started with the fad for so-called designer frames.
                                            Given that frames now come in a seemingly infinite variety of shapes you do wonder how CB go about getting the lenses to fit.
                                            #587680
                                            Bob Unitt 1
                                              @bobunitt1
                                              Posted by David Caunt on 28/02/2022 14:04:00:
                                              Find yourself a new optician. I have several pairs of glasses for different purposes, and I've had new lenses (in one case, just the one eye) fitted on all of them.
                                              #587728
                                                Asda, two pairs for £120, very nice frames (one of mine is Racing Green) and the price includes ultra light lenses, anti-scratch, UV and anti-reflection coatings. Other pair I got are sunglasses with a heavy tint as well.
                                                Other places manage to start at a similar place then by costing in the extras get up around £300.
                                                  Posted by ega on 01/03/2022 11:07:44:
                                                  A routine grinding job for people like this:  https://www.manchesteroptical.com/reglaze-glasses/
                                                  Edited By Michael Gilligan on 01/03/2022 19:26:49
                                                  #587767
                                                  Anonymous
                                                    AFAIK the local optician orders prescription lenses that come in standard, oversize (probably circular) profiles.
                                                    The frame manufacturer publishes a shape code which is plugged into the optician's local shape-grinder machine to make the lens fit the frame. Or a drawing, in which case the optician uses his manual skill to cut the lenses to suit. (Perhaps that's why some opticians can't make lenses to fit some frames).
                                                    At least that's how my guy does it this side of the pond – I can't believe it's any different over there.
                                                    #587788
                                                    Henry Brown
                                                      @henrybrown95529
                                                      I'd guess the lens grinder sets the lenses to the central focal point and CNC grinds the outer profile to a set of parameters provided by the frame supplier.
                                                      I'll ask them for a demonstration when I go next time!
