Gerry`s Beam Engine, part on the drawing missing
Home › Forums › Help and Assistance! (Offered or Wanted) › Gerry`s Beam Engine, part on the drawing missing
  • #475624
    BOB BLACKSHAW 1
      @bobblackshaw1
      I started to make the Gerry`s beam engine a few years ago and gave up for some reason but had made the cylinder and a few other parts. I have started to see If I can finish it but with out the side plates but use a central pillar and use the dimensions on the drawing for the main bushes to locate. I know why I gave up on it as some of the parts are not on the drawings, has any one here got the dimensions for the crankshaft connecting rod centre to centre, I could have a try at guessing but I bound to be wrong.
      Thanks Bob
      #33601
      BOB BLACKSHAW 1
        @bobblackshaw1
        #475634
        geoff adams
          @geoffadams14047
          Hi Bob
          Iam building this engine on and off at the moment if you goggle gerrys beam it will come up with john tom.com there is a copy of the english version there is also a metric drawing listed on the net thats the one one iam making give me a shout if you can find them
          hope this helps Geoff
          #475706
          BOB BLACKSHAW 1
            @bobblackshaw1
            Thanks Geoff,
            I searched Gerry`s beam engine metric and found 21 drawings but this didn't cover all of the engine. But I've done the imperial drawing and still cant find the crankshaft connecting rod.
            Bob
            #475711
              Julius' metric drawings give details of the various parts plus a ctr to ctr distance on the assembly drawing, you would have to see how that compares to your imperial parts but should get you in the right ball park the
              EDIT check your PMs
              Edited By JasonB on 28/05/2020 18:48:23
