Extended reach Dial indicator
Home › Forums › Hints And Tips for model engineers › Extended reach Dial indicator
  • #281693
    Neil Lickfold
      @neillickfold44316
      This is what a made up to enable an extend DTI down a hole to indicate it concentric to the front. As pictured, it was set on the front, as a check for it's effectiveness. It was within 0.02mm of the indicator being on the front of the hole directly. Then it was travelled down the bore to see what the run out was 220mm down the hole. In this case, the bottom of the hole was then zeroed, as well as the front of the hole zeroed. Then the out side turned concentric to these values and a new datum being established to then make the part as concentric as possible to the inner hole. In this case the correction was 0.1mm on the DTI.
      Neil Lickfold
        @neillickfold44316
        Using an equal arm pivot to extend DTI reach
        #281756
        Nick Hulme
          @nickhulme30114
          Nicely thought out setup!
