Experimental engineer
  • #395711
    Chris Shaw 2
      @chrisshaw2
      Hello everyone. I am an experimental engineer engaged in my own workshop in creating apparatus for testing various mechanical engineering prototypes. I have been a Bridgeport man all my life so I have one of these – actually a clone from Taiwan with Mitutoyo positional display on a non-interruptional power supply (couldn't do without it). I also have a Smart & Brown model "A" lathe which I really appreciate and have just bought an Alexander 3D manual diesinker for which I want to source some collets. I am adding a three axis router with 25,000 rpm spindle from a University.
      #40490
      Chris Shaw 2
        @chrisshaw2
        #395748
        David George 1
          @davidgeorge1
          Hi Chris welcome to the forum. It looks that you have a varied engineering skill set and your help will be appreciated but if you need any help just ask on here. It sounds like you have a workshop to be envied.
          David
          #395752
          Brian H
            @brianh50089
            Hello and welcome Chris. That sounds like a nice setup!
            I have an Alexander diesinker but alas, no spare collets..
            #395758
            Rod Ashton
              @rodashton53132
              Chris – Recently made some for a friend on cnc lathe from silver steel. Cut a single compression slit and the runout was less than a thou old money. Well worth a try.
