Expansion Link
Expansion Link
Home Forums Beginners questions Expansion Link
  • #105380
    Deltic007
      @deltic007
      Does anyone know if the Loco LILLA 3.5" guage has 2 Links or just 1.The drawings and EIM write up are not clear…..
      Maybe there is only 1 on every loco and i am showing my lack of experience here but hey ho you gotta learn sometime.
      Just a bit puzzled as there are 4 eccentrics as well,Maybe it will become obvious as i progress but thoughts welcome..
      Deltic 7
      #6476
      Deltic007
        @deltic007
        #105490
        Weary
          @weary
          Maybe you have sorted this already, but………
          Lilla has two expansion links, one for each 'engine' = each cylinder & associated valve gear.
          Each expansion link is driven by two eccentric rods, hence why you have four eccentrics. Each eccentric rod runs from an eccentric to one of the lugs on its expansion link. This 'blog type thing' of a similar (5" gauge) locomotive might give you a bit of help. 'October 2011' shows a reasonable pic of the valve gear, and the associated drawings under 'November 2010' might also be helpful.
          Regards, & good luck!
          Phil
          Edited By Weary on 04/12/2012 23:24:57
          #105664
          Deltic007
            @deltic007
            Thanks
            Sorted now,felt a bit foolish asking.
            #105669
            Steambuff
              @steambuff
              If you don't ask .. you don't learn
              The only stupid/foolish question is the one you don't ask !!
