Ejectors Help Needed
Home Forums Beginners questions Ejectors Help Needed
  • #8063
    Deltic007
      @deltic007
      #230952
      Deltic007
        @deltic007
        Hi,
        I need to fit an ejector to my 71/4 model,does anyone have a drawing they could let me have or is there an article in one of the magazines?
        Cheers n thanks
        #230962
        nigel jones 5
          @nigeljones5
          like the one james bond had in the car?
          #230968
          Deltic007
            @deltic007
            You really expect me to furnish that with something sensible?
            #230969
            Simon Collier
              @simoncollier74340
              Ejectors have not been very well covered. There is a design in Derek Brown's book on injectors. Martin Evans also gave a design in his book, but it didn't work for me. I'll try the Brown one soon and I bet it will work perfectly.
              #230973
              julian atkins
                @julianatkins58923
                Brian Hughes' drawing for ejectors are on the Reeves vacuum braked bogie drawings.
                They differ from the DAG Brown drawings in his injector book. I havent tried Derek Brown's ejector, but I have tried a few versions of the Brian Hughes design.
                The 7.25"g association might be your best bet.
                With vacuum ejectors, the larger you make them the less critical the dimensions become. They are quite forgiving in 7.25"g.
                I have all the taper reamers to make them.
                The steam and air exit pipe off the ejector can have quite an effect on performance. This can easily be seen on test. It needs to be of generous diameter verses length IMHO.
                Cheers,
                Julian
                Edited By julian atkins on 20/03/2016 23:26:06
