Drill chuck keys
Drill chuck keys
Home › Forums › Beginners questions › Drill chuck keys
  • #56264
    Cornish Jack
      @cornishjack
      Hi
      Have recently bought an unusual drill chuck. It is very high quality and apparently unused but minus the key. Is there a standard  set of key sizes/specs or how are they specified? I wouldn’t like to use one of the ‘universal’ 4 way jobs on anything this well made.
      TIA
      Bill
      #5204
      Cornish Jack
        @cornishjack
        #56265
        Dinosaur Engineer
          @dinosaurengineer
          Why not take chuck to your local Cromwell tools ( or DIY store) or equivalent merchant and try a few keys ? Most quality chucks have the manufacturers name on them . A quick Email should illicit the local stockist and price.
          #56292
          Cornish Jack
            @cornishjack
            Thank you, DE. Could well do that but most of the DIY type keys are not exactly precision items!! The manufacturer of this one (MSE) have (I reckon) long since ceased trading.
            Will keep searching.
            Rgds
            Bill
            #56298
            Dinosaur Engineer
              @dinosaurengineer
              Sorry I can’t help any further. I’ve never heard of MSE chucks – were these UK made ? . A Google search didn’t reveal anything. Most of my chucks are Albrecht precision keyless ones. If you could find a key that matches the sleeve teeth & PCD on the chuck then even if the centre shaft on the key is the wrong size you could either turn it down or insert a larger shaft or add a sleeve. If the teeth match is fairly close then as long as you don’t overtighten , it should not damage your chuck. The sleeve teeth may be harder than the key teeth !  Seems a shame to have a good chuck waiting for a key that will never turn-up !
              #56309
              David Clark 13
                @davidclark13
                Hi There
                A good drill chuck should not need a key.
                You should be able to tighten it by hand and the drull should not turn unless you force it into the job.
                regards david
                #56311
                Steve Garnett
                  @stevegarnett62550
                  I can’t be absolutely sure, but I think I’ve seen MSE stuff before. IIRC, they were a South London firm that was certainly operating into the 50’s called Machine Shop Equipment Ltd. They used to make very high quality tooling for aircraft manufacture.
                  #56312
                  John Olsen
                    @johnolsen79199
                    No point gettting a key anyway, it will only get lost. (Says the voice of experience!)
                    I have an old chuck lying around here, just happened to take a closer look. It say Christen Bern No 30 1/2 and has a little shield logo with a Swiss cross in it.  Hmm, looks not too bad, maybe I should clean it up and try it out. Naturally it does not have a key either.
                    regards
                    Anonymous
                      A quick search on the Companies House website reveals a company called Machine Shop Equipment Ltd., which was dissolved in 1995. Unfortunately the data has been archived, so location and business area are not available on the website. There was ‘phone number to call, but I’m not that curious when there’s paid work that needs to be done instead!
                      #56350
                      simon Hewitt 1
                        @simonhewitt1
                        IF you are anywhere near Salisbury, go to Penny Farthing tools. They have a drawer full of odd check keys. I recently got a small lathe with 4 tailstock chucks in 3 different patterns, I got keys from all of them, and I think £5 for all 3. No connection – just a satisfied customer.
                        #56765
                        Sub Mandrel
                          @submandrel
                          In my first job we used 3/8″ drills to make holes in rhododendron stumps, then poured in amcide weedkiller. Using reversible black and decker electric drills with a generator the tightening/untightening technique was to spingup to full speed then grab with leather gloved hand…
                          Don’t try this at home – or yo-yo starting chainsaws, which was another speciality.
                          But why should a cheap 4-way chuck key damage a decent chuck – assuming it has a head the right size?
                          Cornish Jack
                            @cornishjack
                            Thank you all. Apologies for not following up on this but have been (unusually!!) busy.
                             Stub Mandrel – it seems to me that using one of the ‘cheapo’ 4-ways etc. will likely (from past experience) keep slipping out of engagement and require excessive force. May not damage the chuck but doesn’t ‘fit’ the quality of the thing. This chuck has a built-in prism viewer for centring plus adjustment a la Griptru to suit it to different machines. I would like to think that the original maker had supplied it with a key to suit its potential accuracy rather than a ‘bog standard’ device. Apologies to John ‘Bogs’ – apropos which, his user name ought to be ‘Dog’s B*****ks’ given the original derivation of the two … “Boxed Standard” for normal quality and “Boxed de Luxe” (which became ‘bastardised) for the best version
                            Will keep looking.
                            Rgds
                            Bill
                            #57087
                            Axel Bentell
                              @axelbentell
                              Posted by David Clark 1 on 01/10/2010 07:57:09:
                              Hi There
                              regards david
                               I´d like to disagre, it depends on the construction. Like what thread size is used to tighten the chuck with, doubt you can make a drill sit still in any of may smaller chucks (jacobs). I´ve been told and read that we are suposed to use all three holes in the circumferance to tighten it properly. But thats just a myth that got carried away methinks.
                              #57089
                              Sub Mandrel
                                @submandrel
                                I like that, be it gospel or urban legend!
                                John Wood1
                                  @johnwood1
                                  Hi There
                                  regards david
                                   This makes sense although the comment from Axel re thread size probably qualifies the practice, try it and if it works for you then great. This now brings up the question as to whether keyless chucks are good replacements for keyed ones, presumably they are made to give a good grip. A changeover to keyless would certainly solve the usual “where’s that darn key gone” problem.
                                  John Olsen
                                    @johnolsen79199
                                    The keyless ones are arranged so that the forces from cutting will tend to tighten the chuck. This can work well enough that it can be very hard to undo them after using a large drill. Despite that I have still had the drill turn in the chuck. One gotcha with these is that they will undo when the load goes on the other way, say if the drill is sticking in the hole and you turn the machine backwards by hand to try to free it.
                                    I have three keyless ones, the smallest a genuine Albrecht, and two larger far eastern imitations. The Albrecht is noticeably better although the other two are OK, however they are not good for the smaller drills, eg a half inch chuck should not be used for drills below about 1/8″
                                    regards
                                    Sub Mandrel
                                      @submandrel
                                      I have various keyed chucks, Jacobs, Rohm, No-Name and they all work. I have two keyless chucks, both economy models. The one on a portable drill is completely useless, a bigger one I bought as a stand alone needs a gorilla-style grip to tighten. I fitted it to an MT2 shank and keep a centre drill in it.
                                      The lesson, if you buy budget, buy keyed chucks.  I’m sure teh more expensive keyless ones are OK, but I have never bought one.
