drill bit cutter
drill bit cutter
Home Forums Beginners questions drill bit cutter
Viewing 15 posts - 1 through 15 (of 15 total)
  • #103089
    michael burton 1
      @michaelburton1
      hi all i need to make a hole for a 1/2'' stainless ball to fit in, its in a block of ally now i havent got the money to buy a ball nose cutter or material to make a cutter so i was wondering…….
      would using a 1/2'' drill work that will be ground with the correct radi and a cutting edge ground on work for this one off hole
      manythanks mike
      #6426
      michael burton 1
        @michaelburton1
        #103092
        Sub Mandrel
          @submandrel
          Yes
          #103093
          Sub Mandrel
            @submandrel
            Although it might be easier to make a d-bit by rounding the end of a bit of 1/2" silver steel, milling away just under half the thickness and hardening & tempering it.
            Engine Builder
              @enginebuilder
              Mike, you could make a cutter from a bit of 1/2" silver steel. Mill or file down to a couple of thou.more than half the diameter and file the end half round. A 1/2" hole drilled in a piece of sheet can be used as a gauge to get the shape. Remove most of the metal with a standard drill and you your home made one to finish it off.
              #103116
              russell
                @russell
                you could try a (wood working) carbide router bit.
                alleged to work in Al.
                -russ
                #103121
                Ian P
                  @ianp
                  Posted by russell on 08/11/2012 02:08:02:
                  -russ
                  But fot this job, NOT IN A ROUTER!
                  Should be no problem in a pre-drilled dimple at slow speed with plenty pressure, in a pillar drill.
                  Ian
                  #103128
                  Gordon W
                    @gordonw
                    A ball nosed end mill is only a pound or two dearer than the same size drill !
                    #103131
                    Ian S C
                      @iansc
                      If you use a drill bit , it can be put back to normal with little loss of length. Ian S C
                      #103133
                      jason udall
                        @jasonudall57142
                        Does it realy need hemisphere seat?
                        why not use 1/2" drill to depth as required? maybe with pilot hole ( 1/2" center drill ?)
                        #103138
                        Grizzly bear
                          @grizzlybear
                          Lots of good suggestions, but we have only half a story. What is the finished article going to do?
                          Regards Bear..
                          #103142
                          MadMike
                            @madmike
                            A half inch diameter ball nosed end mill is £10.30 from ArcEuro. If you genuinly cannot afford a tenner (?) then regrind a 1/2" drill to give a 90 degree included angle and allow the ball to sit on that. Alternatively put your block of aluminium in a chuck and gring a boring bar bit to create the radius form and simply bore it to size and form. However as GB says we could all do with more information to give accurate advice.
                            #103144
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              (1) If its a job that can be done in a lathe just grind a quarter circle with reliefs on the end of a normal lathe tool bit , set the correct offset and use tool to finish profile a predrilled hole . Slower speeds and cutting oil if you want a nice finish .
                              (2) For a rough and ready but possibly quite adequate spherical seat drill out most of metal with ordinary drill and impact a spare steel ball in the hole a few times . Common Aluminium is so soft that it will deform easily . Controlled pressing in a vice for preference but Birmingham screwdriver would certainly work .
                              MikeW
                              #103157
                              michael burton 1
                                @michaelburton1
                                hi all i looked in my tray of milling cutters and lurking in the amungst them all was a 1/2'' round nose cutter perfect for the job
                                #103183
                                russell
                                  @russell
                                  which represents the biggest problem of all – remembering what one actually has! (not to mention where one put it…)
