Deep but narrow blind slot
Home › Forums › Workshop Techniques › Deep but narrow blind slot
  • #841883
    colin hamilton
      @colinhamilton16803
      I would like to cut  blind slot in the end of a shaft (in the end face if the shaft). The slot needs to be contained within the diameter of the shaft. The cross section of the slot is approximately 20mm by 3mm and I would like it at least 20mm deep. 20mm deep looks way beyond the 3mm end mill i have. What would be the best way of going about this?
      Thanks Colin
      #841884
      Durhambuilder
        @durhambuilder
        Could you machine the end of the shaft smaller than required, cut a slot right across with a slitting saw and then shrink or silver solder a sleeve around the outside to bring back to final required diameter?
        #841886
        Robert Atkinson 2
          @robertatkinson2
          Bit lacking on information. What material? What equipment do you have? How long is the shaft?
          EDM is one option. Failing that you can get long mills..
          #841890
          Tony Pratt 1
            @tonypratt1
            A bit of context is needed as this is really only easily doable with EDM if indeed the part is metal, why so deep and narrow? Can the part be redesigned for ease of manufacture?
            Tony
            #841893
            peak4
              @peak4
              A bit lacking on context, material, and size
              Mill a slot in the side of the shaft, go in with a T-slot cutter, silver solder a bit of metal in the original slot and skim the outer diameter.
              Bill
              #841897
              not done it yet
                @notdoneityet
                Why a blind slot?  If side loaded at the ends, it might make the choice between the Durhambuilder and peak4 options (if going that way) more obvious.
                #841906
                old mart
                  @oldmart
                  I would do it with a 3mm solid carbide end cutting mill, in lots of careful stages being careful to remove all of the swarf each time. By stages, I mean 0.5mm increments which will lessen the danger of breaking the mill. Another way would be to remove most of the metal with a line of chain drilled holes of 2.7mm if using HSS drills or 3mm if solid carbide drills, followed by milling. This would still require very careful progression. The finished slot would not have a perfect surface finish, and the ends would have a 1.5mm rad.
                  #841909
                  cedric 1
                    @cedric
                    Redesign your part so it’s easier to machine. There is always more than one way to skin a cat. What you are proposing, a 3mm closed-end slot 20mm deep, is going to be difficult, albeit doable given enough patience. It might be far easier to eliminate the need for the awkward slot and use a simpler, easier yo make design.
                    #841916
                    Dave S
                      @daves59043
                      Chain drill with a 2.5mm 10D carbide drill to remove the bulk of the material.
                      Then I would plunge cut the majority of the slot with a carbide 3 flute, if possible undersized like 2.8mm
                      Then machine the walls to clean up
                      DC31k
                        @dc31k
                        Any milling solution will be made more difficult by swarf removal.
                        Turning the head of the mill sideways, having the shaft horizontal and starting at the bottom will allow swarf to drop away, as well as facilitating access for a blow gun to keep the cavity clean.
                        The shrink fit sleeve is a good suggestion, but we would need to know the diameter of the shaft. 20mm long in a 25mm diameter item is different to 20mm long in a 60mm diameter item.
                        #841940
                        bernard towers
                          @bernardtowers37738
                          Im with Durham Builder all the way.
                          #841950
                          Grizzly bear
                            @grizzlybear
                            Hi,
                            Why don’t people state its intended use? (Or did I miss it?).
                            #841965
                            colin hamilton
                              @colinhamilton16803
                              Sorry everyone for the lack of context. I’m looking to make a set of rotating skewers for my grill. So its basically going to be a series of gears where the shaft sticks out a way with the slot cut into the end of the shaft. The idea being the kebab skewers are placed into the slot and rotate (I will make some sort of support on the other side of the grill for the handle end of the skewer). I’ve never cut gears before and that is going well. Everything is made of EN3b. The gears are all module 1.5. The gears for the kebabs are 36tooth. I’m going to need to add a couple of speed reduction gears as my motor is running at 40rpm. The bearings I’ve got have a 15mm bore so I was going to drill and tap the ends of the shaft and after the gearbox is assembled i will screw in a bigger diameter section with the slot. I like the idea of cutting the slit all the way across and the silver soldering a sleeve round after. I did some silvering soldering for the first time today as I’m soldering the gears onto the shafts
                              #841976
                              cedric 1
                                @cedric
                                <p style=”text-align: left;”>To rotate a kebab skewer? Is it the type with a round ring on the end? If so, just support the shank of the skewer with a bit of sheet metal with a V notch cut in it. Then just cut a slot all the way across your drive shaft with a slitting saw.</p>
                                #841990
                                Bazyle
                                  @bazyle
                                  If it is a kebab skewer with a loop on the end just screw a cup hook into the end of the shaft. Your precision engineering route will give you all sorts of alignment problems.
                                  #842099
                                  Grizzly bear
                                    @grizzlybear
                                    Hi Colin,
                                    Thanks for the update.
                                    Good luck………
                                  Home › Forums › Workshop Techniques › Topics
