Darjeeling Well tank
Home › Forums › Locomotives › Darjeeling Well tank
  • #144673
    brian bruun
      @brianbruun25047
      Hi fellow modelers
      still collecting and looking at drawings and i Found a problem hopping somone can help me what is the lenght messuret from the bottom of the well tank to the center of the ø5/16 tube going thru the thank. It is Kissinger on the drawings
      regards Brian
      #1257
      brian bruun
        @brianbruun25047
        #144680
        peter ravenscroft
          @peterravenscroft57700
          hello brian
          it is 1 1/4 " from the bottom and 2 3/8" from the back of the tank
          hope this helps
          regards
          peter
          #144776
          brian bruun
            @brianbruun25047
            thanks peter
            could you by any chances tell me what materiel the suspension guides are build i.
            and what does BMS stand for?
            regards brian
            #144797
            Jeff Dayman
              @jeffdayman43397
              BMS=bright mild steel or cold rolled steel
              #144827
              peter ravenscroft
                hi brian
                as already stated bms means bright mild steel if you are looking for ready made part i can recomend blackgates model engineering there catalogue is avilable as a down load
                i.m 4 years in to my build and still have a way to go
                regards
                peter
                #144837
                brian bruun
                  @brianbruun25047
                  hi
                  thanks jeff and peter
                  how far is is youre model peter ? do you have any pic you could send me ?
                  regards brian
                  Edited By brian bruun on 23/02/2014 18:57:54
                  Edited By brian bruun on 23/02/2014 18:58:21
                  #144933
                  peter ravenscroft
                    hi brian
                    send me your e-mail address via a private post and i"ll sort some photo,s out for you
                    regards
                    peter
                  Home › Forums › Locomotives › Topics
