Dake engine suggestion
Home › Forums › General Questions › Dake engine suggestion
  • #113477
    Eric Cox
      @ericcox50497
      When machining the horizontal side rails to length, instead of mounting the rail vertical in the machine vice as shown in ME 4451, mount the rail horizontally in the vice and machine the rail with the side of the end mill. That way you won't have to "sneak up on them with light cuts" and you can measure the overall length without removing from the vice.
      #22496
      Eric Cox
        @ericcox50497
        #113479
        roy entwistle
          @royentwistle24699
          If I can add my own tuppence worth. Would it not be helpfull if we got a materials list at the start of the article then we could order in bulk Thanks
          Roy
          #113576
          roy entwistle
            @royentwistle24699
            I have just been looking at the drawings and I find that on page 352 part 5 the height is given as 81
            howevr on page 353 part 7 the height of the same component is 83 Which is correct ?
            Roy
            also as an aside, the text states that the rails are made from 1 x 5/16 inch bar so why is an Americam machine being made in metric ?
            #113577
              Stew's engines are not to any exact scale, more a general representation of the style, as he tends to work in metric thats why its being drawn mostly in metric. If you happen to know the exact dimensions of the original I'm sure we would all like you to share these but as it is Stew and the rest of us who like to model engines from scratch usually just have a few etchings or old photos to work from.
              The use of commonly available imperial aluminium section makes it easier for builders to get hold of materials and allows for a light clean up skim to be taken.
              J
              #113582
              Sub Mandrel
                @submandrel
                I was musing yesterday that a 1/2 or even 1/3 size version of Stew's model would be a good challenge. It could be simplified as you might as well make some of the parts from solid brass.
                Stewart Hart
                  @stewarthart90345
                  Posted by roy entwistle on 03/03/2013 10:37:12:
                  Roy
                  Whoops sorry Chaps just checked it out and the correct size is 81
                  As for metric imperial switch I just use what ever stock size of material metric or imperial I can lay my hands on that will do the job, when I first started work we were on the imperial system then we changed to metric so I'm ambidextrous and can swap from one to the other with no problem.
                  I like to use metric sizes just to keep the cost down being the industry standard nuts bolts taps dies etc are a lot cheaper that going for BA etc OK you may not be able to scale things as well in metric but it's something I don't worry too much about, I don't want build to competition standard, that is just my way of working.
                  I've not worked to any particular scale in fact I've not tried to model any particular engine, I was just focusing on just getting a running engine that was an approximation of a real jobby. As Jason said working from etches etc is not easy particularly when you have no reference point to work from, and the Dake was particularly difficult as you couldn't see the innards of the engine,
                  Neil's point about size is a good one, the engine turned out to be a bit of a big bruiser, if any of you who've seen the engine at Manchester over the week end may have noticed, it such an odd ball I was very unsure on what size would work, and I think I over did it a bit, if i was to start again, I think it would make it 3/4 or even 1/2 the size that I did.
                  Thanks for you're interst
                  Stew
                  #113644
                  Stewart Hart
                    @stewarthart90345
                    Posted by Eric Cox on 02/03/2013 11:52:21:
                    I missed this bit :- Eric you're correct that would be a better way, sometimes you can't see the wood for the trees ;o)
                    Stew
                    #113691
                      Stew, if part No 7 is made to 81mm it won't leave you any material to mill the assembly square as shown in photo No 14.
                      Would it not be better to make it 83mm and then machine the assembly down to 81mmfinished size?
                      J
                      #113711
                      Stewart Hart
                        @stewarthart90345
                        Thats a good point Jason.
                        When I made mine the part was very close to square so I only had to take a very light skim off each side to get it square:- no more than 0.2mm a side, so to be on the safe side making it 83mm would not be a bad idea.
                        The only thing you would have to be carfull of was keeping the centre of the square (Outer Piston) on the centre line of the crank shaft, otherwise there would be a danger of the inner piston fouling at top or bottom of its stroke, I have drawn it up so there is 2 or 3 mm clearance at the tops of its stroke to help avoid this, but if things did get to far off line, this would be a danger.
                        Its one of those engines where it helps to start getting parts arround you so you can visualise whats happening, when I made it I had to keep going back to the drawing board to tweek things.
                        Thanks again for your interest
                        Stew
