The Triumph is a very well regarded toolroom lathe. The problem really with these and others especially Colchester is that it's very easy to spend a fair amount of money xK on a machine that is well and I really do mean well past it's best. In fact I would go as far as saying that it would be hard to find one that doesn't show signs of wear unless it's been reconditioned and the standards of work when that is done varies. I am comparing against scarcely used machines that really are as new. I've used several including a few that have been made regardless of cost. Curious as it might seem I don't see Colchester in that class. As some one mentioned their Dad mine spent millions on machines. His view of Colchester is that they sorted lathes out and forced others to make more consistent machines in terms of the results from them so bought lots. It would first choice unless unusual accuracy with a decent life was needed.
So really this is the first question. It's possible to buy Chinese lathes that toolroom etc do use these days and it will be brand new. It might not last as long but even that is questionable really as in some areas they all wear fairly quickly if used 8 hours a day / lots of heavy work.
One thing that bugs me academically speaking is how many have got up to carbide speeds – fit a dual speed motor. I really do wonder about that given the spindle sizes in them. Nothing miraculous has happened in the bearings area that they use as far as I am aware.
Another option is a smaller well made machine. I'm happy with my Boxford. It's very easy to buy lathes like this that are well worn as well. The "sad" thing about the Chinese lathes of this sort of size is that to get vaguely similar it has to be somewhat bigger and also a gear head. This seems to be the way lathes are graded these days if it isn't a gear head then it's a hobby machine. There will be exceptions so perhaps hardened, ground, quiet gears has to be added.
Really a lot depends on what you want to make and your expectations. Lathes in particular where there are several of them tend to get used for different jobs as they age because the precision drops off. Often as in toolrooms things get hardened and ground so finish and the rest doesn't matter within rather wide limits. When it does they are disposed of. Colleges are sometimes very stringent in that area and get rid of them a long time before a toolroom would. Schools to for a different reason but it's a good idea to check for abuse damage rather carefully.
Just add another point – a bad one really but it illustrates a principle. Being keen to own one I have a Pultra. Tiny thing but it can turn at 10,000 rpm. Size does matter in this area.
Edited By Ajohnw on 09/03/2016 16:05:24
