Clarkson 8mm Autolock S Type Collet Small
Home Forums Workshop Tools and Tooling Clarkson 8mm Autolock S Type Collet Small
  • #106708
    Graham Wharton
      @grahamwharton
      Hello all,
      Quick one…..Has anyone ever come across a Clarkson Small SType Autolock Collet in 8mm. They appear to be as rare as rocking horse sh*t.
      Thanks
      Graham
      #16959
      Graham Wharton
        @grahamwharton
        #106709
        Tony Pratt 1
          @tonypratt1
          Hi Graham, I don't think they exist as threaded shank cutters in the small diameter range come with 6mm, 10mm, 1/4" & 3/8" shank diameters.
          Tony
          #106710
          Graham Wharton
            @grahamwharton
            I too thought they never existed too however I recently came across a cutter in my garage (which I can no longer remember or find….typical) that was an 8mm threaded shank.
            http://www.cromwell.co.uk/CTL0627010Y
            Clarkson part number 40M92
            A skip through clarkson and dormer cutter catalogues and I cant find any tooling that is 8mm threaded shank.
            #106719
            Deltic007
              @deltic007
              Try Flea Bay
              #106740
              Ian S C
                @iansc
                My Clarkson has collets for 1/4" 5/16" 3/8" 7/16" 1/2" 5/8", And I made one for 3/4". Ian S C
                #106759
                  Graham,
                  Unfortunately this leaflet on the "S" makes no mention of 8mm
                  … although I do vaguely recall that the "S" was updated at some time; so there may still be a chance.
                  Graham Wharton
                    @grahamwharton
                    Ive had a saved search worldwide on ebay for about 8 months now, and nothing has ever triggered it.
                    I think i'll just go hunt the 8mm shank cutter, and throw it if I find it (although I guess I can still use it in my ER32s )
                    If you look at the metric part numbers, the 6,10,12,16 are all sequential numbers, with the 8mm having a somewhat higher number, which would support Michaels thought about an update to the range.
                    I am however more looking to satisfy my major tool OCD.
                    I currently have
                    Clarkson S Small 6mm 10mm 12mm 16mm 1/4" 3/8" 1/2" 5/8"
                    Clarkson S Medium 1"
                    Clarkson S Large 20mm 25mm 32mm 3/4" 1" 1.1/4"
                    Does anyone else get tool OCD and collect "Full sets!!!!" regardless of need? (turns out to be quite an expensive thing to do)
                    #106772
                      Posted by Graham Wharton on 19/12/2012 19:04:47:
                      Graham,
                      If you do that, you are almost guaranteed to locate an 8mm Collet within the week.
                      Bazyle
                        @bazyle
                        Graham,
                        the problem is the varieties one ends up with. Haven't got above S size Clarkson but have 3C, 5C, posilock, clarkson, DA180, some unknowm I got by mistake, so far avoided any ER.
                        #145763
                        John Baldwin 1
                          @johnbaldwin1
                          Hi, I'm new to this forum but 8mm Clarkson Autolock Small S/Type Collet do exist, I have one.. Hopefully I've added a couple of photos to show it.
                          John B
