CBN advice seeked.
CBN advice seeked.
Home › Forums › Workshop Tools and Tooling › CBN advice seeked.
  • #455070
    Johan Crous
      @johancrous15881
      I am in the process of building Harold Hall's grinding rest, along with others as well. I am now also making the grinding head as Mr. Hall described in his book, by using a bench grinder.
      I could not yet find a form 11 Norton wheel in Cape Town. Everyone is sold out.
      I am now thinking of buying CBN and diamond wheels at Amazon.com.
      What grades must I buy? The Aluminium Oxide was 60 grit, but the CBN comes out in several grades. I bought a 150 mm size bench grinder, but I can still use as small as 100 mm wheels.
      #19643
      Johan Crous
        @johancrous15881
        T&C grinding head
        #455071
        John Haine
          @johnhaine32865
          Guidance here – I think I bought the B91. Note that you don't need a guard all round the wheel as they don't shed abrasive or shatter (being made of solid steel), so you can fit a larger one than your grinder normally takes.
          #455103
          ega
            @ega
            I found that a CBN wheel is significantly heavier than a conventional wheel and I think some grinders would struggle to get them up to speed; Gary uses his Acute setup with an extension which allows hand braking – see his advert opposite.
            I have had good results from a diamond wheel from Arc, another of our advertisers, but they were unable to tell me the grit size.
            #455110
            Joseph Noci 1
              @josephnoci1
              Johan,
              I had CBN and Diamond wheels or various grits, shapes and sizes made for me at the place indicated below.
              Pierre was very helpful. They are close to your location ( I am in Swakopmund) and were quick to make.
              Bay Abrasives cc
              60 Worraker Street, Newton Park
              Port Elizabeth, South Africa
              Tel : 041-3653137 Fax : 0862703723
              Cell : 0827826235
              Email : [email protected]
              Web site: **LINK**
              Edited By Joseph Noci 1 on 03/03/2020 05:10:27
              #456823
              Johan Crous
                @johancrous15881
                Posted by Joseph Noci 1 on 03/03/2020 05:07:40:
                Johan,
                Bay Abrasives cc
                Cell : 0827826235
                Web site: **LINK**
                Thank you Joseph,
                Pierre was very helpful and and I will get my CBN wheel tomorrow.
                I will recommend his services to anyone.
                #456831
                Joseph Noci 1
                  @josephnoci1
                  Great! Glad you came right. I really believe in supporting people like that. They make a good product and deliver good service.
                  joe
