Can someone throw light on a steel specification?
Home › Forums › Materials › Can someone throw light on a steel specification?
  • #29515
    Carl Wilson 4
      @carlwilson4
      #152934
      Carl Wilson 4
        @carlwilson4
        Hello chaps,
        I am reading through an old RAE report from the early 50s. It mentions a mild steel spec BSS.S1. I suspect it mighthave a DTD equivalent number but can't find any info. Does anyone here know anything about it?
        Much appreciation in advance,
        Carl.
        #152937
        Russell Eberhardt
          @russelleberhardt48058
          Could this be it? **LINK**
          Russell.
          #152938
          John Stevenson 1
            @johnstevenson1
            S1 is a tool steel ?
            http://www.westyorkssteel.com/tool-steel/s1/
            edit for clicky link.
            Edited By John Stevenson on 19/05/2014 15:19:05
            #152940
            Carl Wilson 4
              @carlwilson4
              Hello Gents,
              Thanks for the prompt replies. John, it isn't the tool steel, I know what you mean though. BSS is an old British Aircraft Industry standard but I can't find much on BSS.S1. There are things like BSS.62 which is a ferritic stainless steel, and BSS.B251 which is a brass. A lot also have DTD numbers. Considering how widely they were once used there doesn't seem to be much info out there.
              So, Russell, you are right, it is the S1 shown on the aero vintage site. Just no spec.
              Thanks again for your searching. I'm going to keep looking, please feel free to shout if you find anything!
              Carl.
              #152942
              Carl Wilson 4
                @carlwilson4
                Hold on…Think BSS.S1 may now be called BS 7s1, as follows:-
                Weight% C Si Mn P+S Pb by agreement Limited Ruling Section
                7S1
                GpA
                0.15-0.25 0.1-0.35 0.6-0.9 0.04 max 0.15-0.35 0-19mm
                7S1
                GpB
                0.25-0.35 0.1-0.35 0.6-0.9 0.04 max 0.15-0.35 19-29 mm
                7S1
                GpC
                0.3-0.4 0.1-0.35 0.6-0.9 0.04 max 0.15-0.35
                29-
                Well maybe…
                #152943
                John Stevenson 1
                  @johnstevenson1
                  Does this mean I have to tie a rope round me chest and delve into the library ?
                  #152944
                  David Jupp
                    @davidjupp51506
                    BSI do have a lot of withdrawn standards still available for purchase – (won't be cheap, but should be definitive if they can help) see this for contact details of their knowledge centre.
                    7S 1 1964 replaced 6S 1 1953
                    Edited By David Jupp on 19/05/2014 16:32:20
                    #152953
                    John Stevenson 1
                      @johnstevenson1
                      OK got the 1940 Aeronautical Handbook
                      Bags of info on all different steel grades
                      Only problem is its the S.A.E. book so everything is American !!!
                      You want propeller boss standards ? Magneto mounts ?
                      I got it in US speak
                      Now if you know the ANSI for S1 I can tell you what's in it !
                      Sorry
                      Edit for spelling
                      Edited By John Stevenson on 19/05/2014 20:11:21
                      #152977
                      Carl Wilson 4
                        @carlwilson4
                        Hello,
                        Thanks for delving into the wilds of the library! Thanks to everyone else for the efforts you've made to help.
                        #152990
                        David Jupp
                          @davidjupp51506
                          Typically the S series are ordinary (old) EN materials, but with more inspection/certification and may also be to a tighter chemical analysis than the 'bog standard' material.
                          For example, one customer users S97 or S154 if EN25 is not obtainable – being aerospace certified it costs a lot more though.
                          #152994
                          Carl Wilson 4
                            @carlwilson4
                            Hi David,
                            Thanks for clearing that up for me. Are you aware of a reference for a list of equivalents ie S types to BS EN? Thanks for everyone's input, greatly appreciated.
                            Carl.
                            Edited By Carl Wilson 4 on 20/05/2014 09:17:36
                            #152995
                            David Jupp
                              @davidjupp51506
                              Sorry, not aware of a cross reference list – though it must exist. I'd be interested if anyone has one.
                              I guess there may be some S grades that don't fall neatly into a single EN grade – perhaps optimised for some specific reason…
                              #152996
                              Carl Wilson 4
                                @carlwilson4
                                Thank you David,
                                I expect you are right, I will keep looking for info and you never know I may come across a list of equivalents. The report I referred to earlier is about a prototype piece of equipment built not long after the war. The authors are at pains to point out that money was short and therefore the unit was machined from BSS.S1 – a very bog standard mild steel by the sound of it – to save money (cheaper, readily available material) and time in terms of easy fabrication.
                                It would still be good to know exactly what it is, it will help me in my interpretation of the report. I can make sense of the design dimensions based around the material properties.
                                Thank you again David, for giving up your time to assist me.
                                Carl.
                                #152998
                                John Stevenson 1
                                  @johnstevenson1
                                  This is a true story and on an old hard drive [ long gone] I used to have the source of the tale below and I would love to get this again if anyone can help.
                                  Pre war, WWII that is every supplier of steel had their own grades.
                                  As soon as war started, it became obvious that something had to be done as the same parts were being manufactured by different companies all over England and so used different suppliers.
                                  Some bright bod in the Ministry of Supply worked this out and a meeting was called in a hotel at Scarborough of the heads of the main steel companies.
                                  When they got there they were led into a conference room, given tea and sandwiches then told they needed to thrash out a new standard they could all work to. As an added incentive they were locked in and told they could come out when they had finished. History doesn't tell us how long this meeting lasted but the result was that until the end of the war everyone would use the same standard called EN which stood for Emergency Number.
                                  This then carried on after tha war until we adopted that abomination of a new standard we have today which is given lip service at the supply level.
                                  You ring my supplier up and say have you got any 55mm BS45M xxxxxxx and he says "Oh you mean EN8 " !!
                                  #153001
                                  Carl Wilson 4
                                    @carlwilson4
                                    Hi John,
                                    I can well believe it. I have sent an email to the restoration centre at the RAF museum Cosford, so they should hopefully be able to help.
                                    Carl.
                                    #153007
                                    Gordon W
                                      @gordonw
                                      John, you are lucky, the best I get round here is " best commercial quality ". I have heard the EN story before but can't remember where, I am originally from that part of the world and always believed it.
                                      #153009
                                      Anonymous
                                        I inherited from my father a small booklet on steel specifications by Firth Brown, published in January 1954. Among the steels listed are British Standards for Aircraft Materials S Steels. The nearest to S1 is 5S1, a 35-45 ton carbon steel for machining. Composition is 0.4%C, 0.05-0.35%Si, 0.5-0.9%Mn and the balance Fe. An equivalent is given as En6, otherwise known as key steel.
                                        #153013
                                        Ian S C
                                          @iansc
                                          Don't know if this is any use; The Vintage Aviator Ltd., in Masterton NZ build WW1 aircraft to the to the original design/drawings, engines included where required. They will have the steel specs for aircraft from around WW1.
                                          You could try this [email protected] Their web site is worth a look regardless.   www. thevintageaviator.co.nz
                                          Edited By Ian S C on 20/05/2014 12:59:07
                                          #153014
                                          Carl Wilson 4
                                            @carlwilson4
                                            Hi Andrew,
                                            Many thanks for that. I may have the spec details I need at home in my own library somewhere, but I'm away from home currently…Interesting you say 5S1 as I earlier came up with 7S1. You are lucky to have such a book. I have a Millwright and Maintenance Engineer's handbook that is full of all manner of interesting bygone specs. However, when I worked on aircraft about 12 years ago they weren't bygone, as all of the British aircraft I worked on were essentially museum pieces (and one or two now literally are).
                                            Thanks again,
                                            Carl.
                                            #153015
                                            Carl Wilson 4
                                              @carlwilson4
                                              Hi Andrew,
                                              Thanks again,
                                              Carl.
                                              #153016
                                              Carl Wilson 4
                                                @carlwilson4
                                                Thanks Ian I'll check it out. I have heard of them anyway. Hopefully my old "Alma Mater" Cosford will come up with the goods.
                                                Carl.
                                              Home › Forums › Materials › Topics
