Boxford back gear
Boxford back gear
Home › Forums › General Questions › Boxford back gear
  • #404941
    kevin large
      @kevinlarge76611
      While drilling a large hole in back gear the small gear broke into pieces it looks like it's been broken before and locktited n the shaft
      My question is how many teeth should there be and what is the pitch is what cutter would I need to make another
      #26555
      kevin large
        @kevinlarge76611
        #404946
        Yngvar F
          @yngvarf
          Is it the small gear on the spindle?
          Lathes
          I think he does a part exchange on the  back gear spindle too.
          Edited By Yngvar F on 13/04/2019 21:04:33
          #404961
          David George 1
            @davidgeorge1
            Why were you drilling a large hole in your back gear!
            David
            #404964
              Posted by David George 1 on 13/04/2019 22:37:28:
              David
              smiley … the wonders of English ambiguity
              #404969
              not done it yet
                @notdoneityet
                You can work out the DP from the diameter and tooth count of the gear which was in mesh with it ( at least, and likely other gears). Now knowing the DP, you could measure the centre to centre distance and work out the other gear tooth count from that. All straight forward once you look up the formulae for sorting out gears.
                #404999
                Dave Halford
                  @davehalford22513
                  From the tumble reverse info on that link it looks like the mk2 is 20pa and the mk1 is 14.5pa.
                  European 20pa cutters are rare secondhand and a lot of new Asian sets are module and not DP, but HPC is another source of machined steel generic 20pa gears.
                  #405013
                  kevin large
                    @kevinlarge76611
                    It looks like a dp16 14.5 pa still not sure how many teeth yet as I can't all the bits
                    So if someone can confirm that would be great
                    #405020
                    Saxalby
                      @saxalby
                      Just measured the small back gear on my Boxford and it is 24 tooth 1.625 inches OD which makes it 16DP
                      #405033
                      Bazyle
                        @bazyle
                        If you make the replacement out of aluminium it will be weaker and act as a sacrificial one for future problems. Then also make it narrower so it cannot be in mesh when the bull wheel is retracted for direct drive. This saves the danger of the back gear left hand lever being engaged when the bull wheel is still engaged with the pulley.
