Boxford as a wood lathe?
Home Forums General Questions Boxford as a wood lathe?
Viewing 3 posts - 26 through 28 (of 28 total)
  • #245617
    Hopper
      @hopper
      Or you could make yourself the Rolls Royce of turning rests, the GH Thomas Quick Action Hand Rest.
      Advantages include that it mounts direct to the bed of the lathe, not the carriage. So the carriage, cross slide, top slide etc etc can be tucked away at the far end of the bed, away from the worst of the sawdust.
      Disadvantages, as with much of GHT's stuff, include that it is a compex way of doing a simple job. He says himself that some would be as happy with a rest made from a bolt and a piece of angle iron (Guilty as charged, yer 'Onor.)
      Drawings are in his book ME's Workshop Manual, or kits are I think available from Hemingway.
      MW
        @mw27036
        "A lathe is a lathe, and I never could really understand how a woodturner could claim a wood lathe was better for tunring wood. To me (and I own a wood turning lathe too) the engineer's lathe has proper precise control of carriage and cross-slide, meaning one can turn wood precisely parallel and to size. Sure; it shrinks and moves later, but that's the wood, not the lathe. My wood lathe says under the bench, out of the way."
        The traditional woodlathe which the metal lathe grew out of, was a traditional craft where most of the work would be carried out freehand. There wasn't a great deal of tolerancing so therefore things were simply made to fit if they needed to be. You have to learn the ability to turn freehand and its not something you can pick up overnight if you want to work well and accurately. Much like filing really.
        Michael W
        #245625
        John McNamara
          @johnmcnamara74883
          Having used a metal lathe a couple of times to turn wood and metal freehand with a simple rest only no tool slides, one thing was made clear right from the start, the turning tool (Must) have a long handle, otherwise there is a risk of the tool being grabbed out of your hand. Where the tool ends up is will be down to luck, hopefully it will not involve putting your hands or other parts of the body at risk.
          There are plenty of videos on the net like this one to see how it is done, **LINK** or just search for wood turning videos.
          Note the long handled tools and the the way the tool is gripped firmly with both hands, and for heavier work under the arm as well. The tool has to be controlled at all times.
          One project was was to make a decorative spindle out of mild steel to match a broken antique part. The tool was a piece of high speed steel. until I fitted a long and sturdy handle it was uncontrollable. The tool wanted to dig in and wrench itself out of my hands.
          Once you get the hang of it freehand decorative turning is very enjoyable, without the limitations of cross slide and top slide XY travels you are able to create on the fly without constraint. Invigorating!
          Edited By John McNamara on 06/07/2016 13:22:23
