April questions—for one day only.
Home › Forums › The Tea Room › April questions—for one day only.
Viewing 25 posts - 1 through 25 (of 25 total)
  • #36812
    Steven Corston
      @stevencorston14096
      #592300
      Steven Corston
        @stevencorston14096
        I understand that the centre in the headstock end is a live centre and that in the tailstock is a dead centre. The live centre is soft whereas the dead centre is harder, or if you prefer, stiffer. Is this because rigor-mortis has set in?
        One of my lathes claims to be a precision lathe. What modifications do I need to make to do non precision work on it? And is it easy to convert it back to precision should I need to?
        Have I been scammed by lathe manufacturers? On the front of my lathes there is what the makers describe as a lead screw. On close inspection I find that this component is in fact made of steel and not lead.
        Why is it called a cross slide when it goes backwards and forwards? Nor does it seem any angrier than the rest of the lathe.
        This next one affects all of my lathes and so it must be a common problem. If I run the lathes forwards they cut metal off with no problem, BUT if I run them backwards they just will not put metal back on. Do I need to fit the tool upside down or back to front-?
        #592301
        Paul Lousick
          @paullousick59116
          It is the 1st of April wink
          #592302
          Grindstone Cowboy
            @grindstonecowboy
            Hang on a minute… these sort of questions sound a bit familiar devil
            Nice one Steven.
            Rob
            #592303
            Mike Rogers 2
              @mikerogers2
              I've got a QCTP on my lathe. Is it necessary to change over to the lantern tool post when machining at night?
              #592304
              jimmy b
                @jimmyb
                Thank you Steven, put a smile on my face!
                Jim
                #592325
                Nick Clarke 3
                  @nickclarke3
                  Like most others my lathe has a head stock and a tail stock.
                  But a word of warning to others – both head stock and tail stock make appalling soup.
                  #592326
                  john halfpenny
                    @johnhalfpenny52803
                    Yes Mike, you do need a lantern tool post at night – but don't forget you will also need a matching lantern chuck
                    Edited By john halfpenny on 01/04/2022 09:15:18
                    #592328
                    Dave Halford
                      @davehalford22513
                      Given the cost of power these days the lantern tool post or better still an original Victorian candle tool post if you can find one could save you a great deal of money.
                      #592330
                      Speedy Builder5
                        @speedybuilder5
                        My drill won't fit into my chuck, the battery and motor stick out too far – what am I doing wrong?
                        I Diot
                        #592340
                        john halfpenny
                          @johnhalfpenny52803
                          Very illuminating Dave, but surely only suitable for light machining.
                          #592341
                          Steven Corston
                            @stevencorston14096
                            I thought a lantern tool post was just for light machining.
                            #592342
                            Nick Wheeler
                              @nickwheeler
                              Not if you use bright steel.
                              #592344
                              Dalboy
                                @dalboy
                                Hot rolled steel is used to keep the workshop warm
                                #592348
                                Nigel Bennett
                                  @nigelbennett69913
                                  Oh give it a rest… steady on!
                                  #592362
                                  Dave Halford
                                    @davehalford22513
                                    Free machining steel comes with free electricity vouchers.
                                    #592414
                                    Howard Lewis
                                      @howardlewis46836
                                      Ah! Thats why I had an argument with the stockist over being charged for free machining steel!
                                      And I thought that pig iron always produced curly swarf!
                                      #592419
                                      larry phelan 1
                                        @larryphelan1
                                        Nice to get a new angle on these things, but how much is true ?
                                        I think some of it is a bit rough, but maybe thats the drill.cheeky
                                        #592420
                                        David Millar 3
                                          @davidmillar3
                                          Does steel wool come from hydraulic rams?
                                          #592424
                                          Grindstone Cowboy
                                            @grindstonecowboy
                                            Apparently the customs papers for a chap importing hydraulic rams into Zimbabwe were maked "Livestock" frown
                                            Rob
                                            #592426
                                            Howard Lewis
                                              @howardlewis46836
                                              Seriously, I believe that someone in the far east translated "Hydraulic Ram" as "Water Buffalo"!
                                              Talk about being lost in translation!
                                              #592431
                                              Georgineer
                                                @georgineer
                                                Posted by Grindstone Cowboy on 01/04/2022 16:53:33:
                                                Rob
                                                This can be turned to advantage. When Dad was in senior management in Portsmouth Dockyard during the 1960s, the medical centre applied to buy an electro-cardiograph machine, a very expensive thing in those days. It was turned down by the finance department.
                                                On being told of this, Dad said to the chief medic (who came under his aegis ) "Hmm… So in effect you are measuring the hardness of men's hearts?" and got the reply " Well, yes, in a way that's true." "Leave it with me," said Dad, and resubmitted the order under the engineering budget as a hardness tester. It went through without question.
                                                George
                                                #592467
                                                Mick B1
                                                  @mickb1
                                                  Posted by David Millar 3 on 01/04/2022 16:49:35:
                                                  My granddaughter actually asked yesterday if it came from robot sheep !
                                                  #592468
                                                  Mick B1
                                                    @mickb1
                                                    Doh! Duplicate…
                                                    Edited By Mick B1 on 01/04/2022 21:04:57
                                                    #592490
                                                    Nick Clarke 3
                                                      @nickclarke3
                                                      Ordered some alcohol free beer but I was made to pay for the alcohol. Now is that fair?
