So it depends on the metal a lot in terms of the age hardening, but can vary from 5-10 days depending, and this normally ends you at T42 temper state. (The T is temper, the first number is the state and the second number is the amount of solution heat treatments it’s had)
to get to T6 see you would artificially age at a lower temp normally around 190*c ish depending on metal and for anywhere from 8-16hrs. Again varies on type of alloy.
the first treatment is SHT solution heat treatment where is high temp (like 500*c) for a shorter time (30 mins varies on thickness) and is then immediately quenched (this is very time critical)
the metal is then as soft as an annealed peice for a short period of time. It age hardens quickly. You can hold this state by freezing it. And then depending on what T state you want, begin your Precip…..
I could bore you for ages on this. We do a lot of sheet metal work on aircraft and do a lot of this. Many variables depending on metal and thickness and what you want to do with it….
